Paisleyjim Posted August 8, 2014 Share Posted August 8, 2014 Well guys. I was just having a look at my spark plugs today and took the oil cap of the rocker cover and noticed some sort of marks inside. (See pics) Also I noticed droplets of water inside where the spark plugs go and a dust that looks like fine rust any idea what it is Sent from my iPad using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted August 8, 2014 Share Posted August 8, 2014 The marks on the camshaft are normal. After the camshafts are casted the excessive material is removed with a grinding machine and the camshafts are balanced by removing excessive weight. Both processes can cause these marks on the camshafts. Water ingress in the spark plug holes is a known problem of the 1.4 and 1.6 Duratec engines of the Focus MK2/MK2.5. The problem is caused by leaking washerjets. Installing new washerjets (with an improved rubber gasket) or applying sealant between the washerjets and the bonnet solves the problem. 1 Quote Link to comment Share on other sites More sharing options...
Paisleyjim Posted August 8, 2014 Author Share Posted August 8, 2014 Ahh cheers for that. Thought something was gonna go in my car Sent from my iPad using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 8, 2014 Share Posted August 8, 2014 Well guys. I was just having a look at my spark plugs today and took the oil cap of the rocker cover and noticed some sort of marks inside. (See pics) ImageUploadedByFord OC1407510719.146691.jpgImageUploadedByFord OC1407510731.894643.jpg Also I noticed droplets of water inside where the spark plugs go and a dust that looks like fine rust any idea what it is Sent from my iPad using Ford OC common problem exclusive to the 1.6 petrol focus, Well happens all focus but only affects the 1.6 petrol engine, The main issue is the seals around the washer jets have perished allowing water to leak in to the engine bay, Due to the design of the 1.6 petrol the rain water leaks in through the ignition lead seals allowing water inside the rocker cover housing, Some clear silicone under the washer jets on the bonnet to start mate, 1 Quote Link to comment Share on other sites More sharing options...
Paisleyjim Posted August 8, 2014 Author Share Posted August 8, 2014 Yeh think il do that tomoz. Is it bad for the engine if water gets into the spark plugs ? Sent from my iPad using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 8, 2014 Share Posted August 8, 2014 Yeh think il do that tomoz. Is it bad for the engine if water gets into the spark plugs ? Sent from my iPad using Ford OC more of an issue in the winter when it freezes mate Ive saw worse cases where the plugs were swimming in the block, Ideally plugs should be insulted from moisture let alone water but we have diagnosed the root cause. Quote Link to comment Share on other sites More sharing options...
Paisleyjim Posted August 8, 2014 Author Share Posted August 8, 2014 Cheers. Would love to clean out all the dust might do that when I take the rocker cover off to paint it Sent from my iPad using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 8, 2014 Share Posted August 8, 2014 Cheers. Would love to clean out all the dust might do that when I take the rocker cover off to paint it Sent from my iPad using Ford OC artscot took his off and painted had same issue perhaps he has a link to a thread Quote Link to comment Share on other sites More sharing options...
Paisleyjim Posted August 8, 2014 Author Share Posted August 8, 2014 Cool il try and look for it Sent from my iPad using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
