Marks12 Posted September 16, 2014 Share Posted September 16, 2014 I got a Toshiba laptop last month and it keeps failing to configure windows up dates any ideas how to prevent this from happening or to make it worse bare in mind I don't have a windows disc Quote Link to comment Share on other sites More sharing options...
volts Posted September 16, 2014 Share Posted September 16, 2014 Check update history in Windows Update see which has failed to install if any. Quote Link to comment Share on other sites More sharing options...
Hyrule Posted September 17, 2014 Share Posted September 17, 2014 What version of windows are you using, XP, 7, 8? What is the need for using Windows update, is there a specific update/patch you require? I recommend to most people to turn Windows update off unless you specifically need a patch/update. Just install the latest service pack for your OS version and you should be good to go. Quote Link to comment Share on other sites More sharing options...
Marks12 Posted September 17, 2014 Author Share Posted September 17, 2014 The version is windows 8 just that it tells me if I want 8.1 then it will need some system updates Quote Link to comment Share on other sites More sharing options...
Hyrule Posted September 17, 2014 Share Posted September 17, 2014 If you want to update to Windows 8.1, you can do so without using Windows update/Microsoft store. See link below and follow instructions: http://www.microsoft.com/en-gb/download/details.aspx?id=42327 As a precautionary measure always backup any important files before the update. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 18, 2014 Share Posted September 18, 2014 I tend to clear the updates cache, then restart the pc and it tends to work! Quote Link to comment Share on other sites More sharing options...
Marks12 Posted September 18, 2014 Author Share Posted September 18, 2014 Thanks for the tips guys I'll try all these when I'm home from work or else the lap top will be flung at a tesco customer service staff Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 18, 2014 Share Posted September 18, 2014 Haha, they won't be able to do anything get the error code from the update history and Google it for further advice. If all else fails system restore to before the last update, move the download cache to a subfolder then update again Quote Link to comment Share on other sites More sharing options...
Marks12 Posted September 18, 2014 Author Share Posted September 18, 2014 Haha, they won't be able to do anything get the error code from the update history and Google it for further advice. If all else fails system restore to before the last update, move the download cache to a subfolder then update again They can give me a full refund is what they can do haha Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 18, 2014 Share Posted September 18, 2014 Haha for a windows issue you probably won't have any luck Quote Link to comment Share on other sites More sharing options...
bensambrook Posted September 19, 2014 Share Posted September 19, 2014 Smash it up and buy a MacBook Pro :P 1 Quote Link to comment Share on other sites More sharing options...
Marks12 Posted September 19, 2014 Author Share Posted September 19, 2014 Smash it up and buy a MacBook Pro :P Only problem is I don't like anything made by apple ;) 2 Quote Link to comment Share on other sites More sharing options...
Marks12 Posted September 23, 2014 Author Share Posted September 23, 2014 OK running a system restore now cause guess what it happened again Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 24, 2014 Share Posted September 24, 2014 Very odd. If this fails do a factory restore Quote Link to comment Share on other sites More sharing options...
SandyCat Posted September 26, 2014 Share Posted September 26, 2014 When you get your list of available updates try unticking all but the top one and install that first. If it works reboot the laptop and try again with the rest. If it works great. If it doesn't then repeat above one at a time until they are all done. Quote Link to comment Share on other sites More sharing options...
Marks12 Posted September 26, 2014 Author Share Posted September 26, 2014 No worries thanks for the help brought it back to tesco got money back for it haha woo off to get a new one tomorrow Quote Link to comment Share on other sites More sharing options...
Wheels93 Posted October 7, 2014 Share Posted October 7, 2014 When installing windows 8.1 if you have got the laptop out the box with windows 8 it wont install straight away. And i am certain i know what to do know you have done a factory reset. Boot into windows 8 as you have been being and move your mouse into the top right hand monitor and you will see a bar appear. Top option is to search, search for windows updates and search for updates. Install the ones that have appeared and then reboot. Once this has been completed you will be able to install windows 8.1 from the store. Unfortunately most people arent aware that when installing 8.1 some prereqs need to be met and these include those updates. Quote Link to comment Share on other sites More sharing options...
Goodkat Posted October 7, 2014 Share Posted October 7, 2014 Quote Link to comment Share on other sites More sharing options...
