Nick1977 Posted April 17, 2015 Share Posted April 17, 2015 Hi new member, so apologies if this is in the incorrect place. I've noticed a clunking noise at the rear of the car when driving over pot holes. Thinking it's rear sub frame bushes. Been to one garage just to get a quote, said he only replace the whole sub frame and that he doesn't fit just the bushes. Is this correct? Thanks Quote Link to comment Share on other sites More sharing options...
pragmatix Posted April 17, 2015 Share Posted April 17, 2015 No the only reason to change the sub frame is ifits corroded, bushes are a straight forward job, I did mine on my Mk3 estate and they have just been done on my mk4 estate, upgrade bushes are available for the saloons but not the estate. Do a search for polybushes it will give a couple of how todos also what's available, if you ok with tools it not a bad job. Quote Link to comment Share on other sites More sharing options...
Nick1977 Posted April 17, 2015 Author Share Posted April 17, 2015 Hi thanks, I've seen them on eBay. Think they're a red colour. Do i need a specific tool to change them? Quote Link to comment Share on other sites More sharing options...
pragmatix Posted April 18, 2015 Share Posted April 18, 2015 Do a web Search for changing subframe bushes on mk3 Mondeo there are a couple of good how tos out there Quote Link to comment Share on other sites More sharing options...
Nick1977 Posted April 18, 2015 Author Share Posted April 18, 2015 Thanks I'll have a look through. I've found on eBay the poly bushes also the tool for the removal and fitting. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted April 18, 2015 Share Posted April 18, 2015 There are 2 different sets of bushes the main subframe and the trailing arm bushes the tool is for the trailing arm bushes Quote Link to comment Share on other sites More sharing options...
Nick1977 Posted April 18, 2015 Author Share Posted April 18, 2015 Ah right. I'm going to have to consult the Oracle (haines manual) as I've absolutely no idea which set is causing the knocking. Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 18, 2015 Share Posted April 18, 2015 The main subframe bushes are glued in originally, fordpartsuk used to sell the kit. Quote Link to comment Share on other sites More sharing options...
Nick1977 Posted April 18, 2015 Author Share Posted April 18, 2015 Ok thanks. I'll have to double check which is which before i start buying parts. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted April 18, 2015 Share Posted April 18, 2015 The main sub frame ones are hard to get out but not impossible you have to burn them out then clean up with wire brushes then you use the old bolts and washers to press them in Quote Link to comment Share on other sites More sharing options...
Nick1977 Posted April 18, 2015 Author Share Posted April 18, 2015 How would i know what's causing the problem, without taking it a garage? Is there away of testing them? Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 18, 2015 Share Posted April 18, 2015 Stick a big lever in and start playing about, see if you can get any movement on any of the bushes Quote Link to comment Share on other sites More sharing options...
Nick1977 Posted April 18, 2015 Author Share Posted April 18, 2015 Ok thanks I'll give it ago. Quote Link to comment Share on other sites More sharing options...
Meercat Posted April 22, 2015 Share Posted April 22, 2015 Ford quote 1.7 hours for both sides, labour, Just recently had mine done on my Mk4, removal of subframe is not nescessary. It's only last year when Ford decided to sell bushes for the Mk4. Only one of mines was defective, I had them both done Quote Link to comment Share on other sites More sharing options...
Nick1977 Posted April 24, 2015 Author Share Posted April 24, 2015 Just been to ATS to have it checked out. Apparently it's the rear drop links. One has gone and one is on its way out. They've said it's £97 for the pair fitted and tracked. eBay sell a pair for a tenner. Are they easy to fit? Look like it's just a couple of nuts. Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 24, 2015 Share Posted April 24, 2015 Hahahah sounds like ATS. Yes they are very easy to replace, and there's no need to have tracking done either! up to their old tricks like kwik fit and the likes Quote Link to comment Share on other sites More sharing options...
Nick1977 Posted April 24, 2015 Author Share Posted April 24, 2015 Ahh well I'll order the parts and do it myself stuff them. At least they've identified the problem. Quote Link to comment Share on other sites More sharing options...
