Robmc Posted June 26, 2015 Share Posted June 26, 2015 Hi. I have a 2006 1.4 fiesta that has just developed an ABS problem. DTC C1095 (ABS Hydraulic Pump Motor Circuit Failure) — Sets when the ABS module detects an open circuit, a short to voltage or ground or a defective internal power transistor during normal operation or the ABS module self-test. The garage said that the module was more likely the problem. So £100 second hand unit acquired, fitted and I still have the same error and cannot clear it. The fuse is ok, the pump module is changed, that only seems to leave the wiring. after all the aggravation and cost I have had, I'm so not bother about having ABS. Does anyone know what wire could be at fault or how to permanently disable the dashboard ABS light? Quote Link to comment Share on other sites More sharing options...
