rulie630 Posted September 2, 2009 Share Posted September 2, 2009 i have just bought an escort and the temp gauge show overheat with the ignition off. i took the thermo out and boiled it in a pan and it worked i tried disconnectng the plugs on the hoses and thermo housing no change i have not run it long enough to see if the fan cuts in when it actually does get hot but when i turn the a/c on the fan kicks in i just dont know what to do cos it may blow the head gasket or may already have the oil looks ok tho any ideas? Quote Link to comment Share on other sites More sharing options...
strumfinger Posted September 22, 2009 Share Posted September 22, 2009 hi there im not to show but it may be the temp gauge nay need a new one hope that helps you there Quote Link to comment Share on other sites More sharing options...
Andy par Posted September 26, 2009 Share Posted September 26, 2009 i have just bought an escort and the temp gauge show overheat with the ignition off.i took the thermo out and boiled it in a pan and it worked i tried disconnectng the plugs on the hoses and thermo housing no change i have not run it long enough to see if the fan cuts in when it actually does get hot but when i turn the a/c on the fan kicks in i just dont know what to do cos it may blow the head gasket or may already have the oil looks ok tho any ideas? Hi mate its either temp gauge on temp sensor Quote Link to comment Share on other sites More sharing options...
mintalkin Posted September 27, 2009 Share Posted September 27, 2009 check that the wireing to the temp sender is not earthing out anywhere. Quote Link to comment Share on other sites More sharing options...
