Cookey09 Posted October 30, 2015 Share Posted October 30, 2015 Alright everyone, so, after some research looking into some sort of ambient lighting kit, I came across the Osram ambient lighting kit for £99.00, thought this was a bit steep for what it actually is! If it was cheaper fair enough... found myself inspired by this which made me go for a cheaper, but just as good alternative... bought a Dual Port USB 'charger' for the 12v socket, and bought two USB powered Self-Adhesive LED Strip lights... the length of the USB cable is pretty lengthy, long enough to go down the side of the centre console and the light strip to stick to the underside of the seats. I dont think they are switched controlled, but, for whenever I have any backseat passengers, i'll just plug in the 2 USB's... and un-plug once they are out. ;) I havent installed them yet, but i've plugged them in using my setup and they are really good! Just thought i'd drop it in, incase anyone was interested in doing a similar thing. 1 Quote Link to comment Share on other sites More sharing options...
CREED Posted October 30, 2015 Share Posted October 30, 2015 It is fairly handy having some extra light in the back but more important foot well illumination looks cool :D Can't fault your method for ease of install but if you ever fancy fitting a more permanent system i.e. hard wiring it, it's a fairly easy job and gives great, neat results. 1 Quote Link to comment Share on other sites More sharing options...
Cookey09 Posted October 30, 2015 Author Share Posted October 30, 2015 I might do mate, just fancied something in the meantime, if I ever do I'll let you know! I'd do it now, but I've got plans on the little things I want doing haha!😋 cheers though buddy. Quote Link to comment Share on other sites More sharing options...
Sgreen93 Posted November 1, 2015 Share Posted November 1, 2015 It is fairly handy having some extra light in the back but more important foot well illumination looks cool :D Can't fault your method for ease of install but if you ever fancy fitting a more permanent system i.e. hard wiring it, it's a fairly easy job and gives great, neat results. SAM_1904.JPG That looks brilliant! I would be very interested in fitting a permanent system, do you know of any guides for doing it? 1 Quote Link to comment Share on other sites More sharing options...
CREED Posted November 1, 2015 Share Posted November 1, 2015 That looks brilliant! I would be very interested in fitting a permanent system, do you know of any guides for doing it? I'm not aware of any guides but it's a fairly simple process. In fact the most time is spent running the wires under the carpet. In a nutshell: 1. Find a 12V feed to use as your power source. Best switched live is probably the cigarette lighter, in my case I took power of the LED scuff plate 2. Decide on a neutral/earth point to use, this should be any unpainted metal but it's worth checking with a multimeter 3. Run wires from these points to each LED strip, going under the carpet/trim, in my case I had one in each footwell 4. Install the LED strips, I used double sided tape for the front and tucked them under the elastic already in place under the front seats 5. Crimp the wires and LED strips together 6. Reassemble the trim and you're done Hopefully that helps 1 Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted November 1, 2015 Share Posted November 1, 2015 In my car I have two aluminium mounted led strips under both seats & one in each front footwell. All are linked to the interior light. So when the interior light is on, the front and rear footwell lights come on Quote Link to comment Share on other sites More sharing options...
Cookey09 Posted April 23, 2016 Author Share Posted April 23, 2016 On 31 October 2015 at 9:52 PM, GingerFlame said: In my car I have two aluminium mounted led strips under both seats & one in each front footwell. All are linked to the interior light. So when the interior light is on, the front and rear footwell lights come on A little bit late.... So are you saying when you click the switch for the map lights? The under seat lights come on? Quote Link to comment Share on other sites More sharing options...
cyberbob69 Posted April 23, 2016 Share Posted April 23, 2016 Looks good Cookey. Fitted some in mine today also, I'll get some shots up when I get chance. I wanted to wire them to when the auto lights come on they come on. But the fuse was in the engine compartment. So I wired to the ignition fuse. But I also fitted a cheap in-line remote, so I could switch them off during the day. 1 Quote Link to comment Share on other sites More sharing options...
Cookey09 Posted April 23, 2016 Author Share Posted April 23, 2016 I've removed mine since the original post. And ah right I get you, sounds interesting. You got a link for your lights? I'm interested in some.. again... But struggling to find some that can be hardwired. Because, correct me if I'm wrong but I'd need an earth and just the one live cable... Quote Link to comment Share on other sites More sharing options...
cyberbob69 Posted April 24, 2016 Share Posted April 24, 2016 Yeah, Just above the fuse box in the glove compartment is bare metal with bolts on it. That's where I connected the negative. Took more time to hide all the wires. Installed 4 in total. Front footwells and under seats for rear passengers. Wasn't 100% with them being full on that's why I brought the remote. Worked a charm, less than £2 I can dim the lights as much as I want can even set them to pulse/flash or random. 1 Quote Link to comment Share on other sites More sharing options...
Cookey09 Posted April 24, 2016 Author Share Posted April 24, 2016 Cheers for that mate. I'll have a look at the links and that tomorrow. RE:the metal bolts etc.. Near the fuse box, yeah that's where I earthed my dashcam. Thanks again. Looks spot on! Quote Link to comment Share on other sites More sharing options...
Cookey09 Posted April 24, 2016 Author Share Posted April 24, 2016 7 hours ago, cyberbob69 said: Yeah, Just above the fuse box in the glove compartment is bare metal with bolts on it. That's where I connected the negative. Took more time to hide all the wires. Installed 4 in total. Front footwells and under seats for rear passengers. Wasn't 100% with them being full on that's why I brought the remote. Worked a charm, less than £2 I can dim the lights as much as I want can even set them to pulse/flash or random. How'd you manage to run the lights to under the rear seats, the wires don't really look long enough mate? Quote Link to comment Share on other sites More sharing options...
cyberbob69 Posted April 24, 2016 Share Posted April 24, 2016 Just brought some extra wire, The wire was probably the most expensive bit, cost about £4. The double sided tape isn't the best to attach to fabric. Fit's good to the plastic at the front just not on the seats. I'll get some shots done this week. Thinking about getting some more lights to fit 1 just above the glove box. Quote Link to comment Share on other sites More sharing options...
CREED Posted April 27, 2016 Share Posted April 27, 2016 That is exactly the setup I used in terms of the electronics. As for attaching the led strips the passenger side is the problem. There aren't enough surfaces allow you to attach them so they are really strong with just tape, also in my experience passengers tended to knock them about a bit. My solution was to use a piece of low profile plastic trunking, drill a couple of holes through it and through the piece of rigid carpet which holds the sync unit and bolt the two together. Then mount the led inside the trunking, obviously the lid isn't needed. PS. don't forget to cut out holes for the Ford footwell light and to allow you reinstall the pins which hold the rigid carpet in place. It sounds a lot of work but it is honestly worth doing. Quote Link to comment Share on other sites More sharing options...
