chris pickard Posted January 24, 2016 Share Posted January 24, 2016 Hi can anyone help I've got airbag light seems to b module can anyone direct me to wiring diagrams for module as need to check live/earth feeds any help would greatly appreciated cheers Chris. Quote Link to comment Share on other sites More sharing options...
iantt Posted January 24, 2016 Share Posted January 24, 2016 hi, whats the problem? and what dtcs for srs do you have? then we could advise what the next step is, rather than blindly doing voltage , earth tests Quote Link to comment Share on other sites More sharing options...
chris pickard Posted January 24, 2016 Author Share Posted January 24, 2016 hi iantt airbag light constantly on bin this way for over a month mot due tomoz assuming its module due to light not flashing just need to know if its module or wiring p.s. wot do u mean by dcts....? Quote Link to comment Share on other sites More sharing options...
iantt Posted January 24, 2016 Share Posted January 24, 2016 can be anything with light on permanantly, dtc, diagnostic trouble codes, wondered if you have had someone read the codes with and abs code reader. that would make diagnosis the fault easily, what i would do without any idea of where the fault lies is to make sure ign off for a few minutes (gives the module time to power down) then unbolt the seat conectors (7mm headed bolt) on both seats, located just under front seats. then refit connectors and pinch up the bolt. switch ign on and see if light goes out. quite common for poor connection creating higher than anticipated resitance. worth a go first, failing that then reader needs connecting and codes read. Quote Link to comment Share on other sites More sharing options...
chris pickard Posted January 24, 2016 Author Share Posted January 24, 2016 (edited) Took it to ford fri and independent wed previous both cudnt connect airbag side of things that's why I think it's module having module tested tomoz if I have to replace is it plug n play as long as I match serial number or will module need programming ???? Edited January 24, 2016 by chris pickard More info to put Quote Link to comment Share on other sites More sharing options...
chris pickard Posted January 24, 2016 Author Share Posted January 24, 2016 More info to come Quote Link to comment Share on other sites More sharing options...
chris pickard Posted January 25, 2016 Author Share Posted January 25, 2016 Hi module gone for tests will know more in 3-5 days Quote Link to comment Share on other sites More sharing options...
chris pickard Posted January 26, 2016 Author Share Posted January 26, 2016 Hi module been for tests it's knackered so need to buy another does anyone know if I get a replacement that match serial no on mine will it just b a straight fit and plug in or will it need programming to my car???? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 26, 2016 Share Posted January 26, 2016 Same model should do it, but best to get as close to the serial as possible Sent from my GT-I9195 using Tapatalk Quote Link to comment Share on other sites More sharing options...
chris pickard Posted January 27, 2016 Author Share Posted January 27, 2016 THanks jeebowhite just ordered exact unit numbers letters and all arriving tomoz so fingers crossed Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 27, 2016 Share Posted January 27, 2016 best to disconnect the battery for 60 minutes prior to play, the slightest delivery of electric charge and you could find all your airbags going off! Quote Link to comment Share on other sites More sharing options...
chris pickard Posted January 27, 2016 Author Share Posted January 27, 2016 Will do thanx again Quote Link to comment Share on other sites More sharing options...
chris pickard Posted January 29, 2016 Author Share Posted January 29, 2016 Well new module fitted plugs under seats disconnected reconnected ffin aorbag light still on 😣😣😣😣 Quote Link to comment Share on other sites More sharing options...
chris pickard Posted January 29, 2016 Author Share Posted January 29, 2016 Need help again please fitted new airbag module light still on took to garage to get it reset but again garage could connect to every system apart from airbag anyone got any ideas apart from scrapping car Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 2, 2016 Share Posted February 2, 2016 sounds to me like the issue is more the wiring... I had this issue in my mk4 shortly after buying, though I could still connect to the module... it was a bad connection between the offside rear curtain bag and its wiring. Quote Link to comment Share on other sites More sharing options...
