ayrshiredude Posted July 26, 2016 Share Posted July 26, 2016 So I was investigating a rattle and managed to break the end off the Glovebox Ambient Light strip, where the strip connects to the LED adapter behind the Glovebox (photo attached.). Can anyone suggest a way that I could fix this rather than spending lots of money buying a new one? Thanks Quote Link to comment Share on other sites More sharing options...
alexp999 Posted July 26, 2016 Share Posted July 26, 2016 superglue? Might affect light output though. Quote Link to comment Share on other sites More sharing options...
laumk7 Posted July 26, 2016 Share Posted July 26, 2016 The fact that wee bit of plastic suggests to me at least that the lights power source is probably fine wire, in which case superglue isn't going to help at all. I think to put it bluntly it's going to be a new one from ford's. Let's just hope the cost isn't too high, no danger of falling back on warranty either as the damage was self inflicted. Another option is to contact a car breakers off eBay breaking the right car Did you find the source of the rattle? Quote Link to comment Share on other sites More sharing options...
ayrshiredude Posted July 29, 2016 Author Share Posted July 29, 2016 there is a small LED attachment that the end of the plastic strip plugs into. this lights up and transfers the light along the whole strip. Unfortunately the end bit that broke off was stuck in the LED attachment and broke into a hundred pieces trying to get it out. I did find the source of the rattle but I am way to embarrassed to tell on here 1 Quote Link to comment Share on other sites More sharing options...
laumk7 Posted July 29, 2016 Share Posted July 29, 2016 You see, now you've got me curious 1 Quote Link to comment Share on other sites More sharing options...
ayrshiredude Posted July 29, 2016 Author Share Posted July 29, 2016 well a few weeks ago I one of my headlight bulbs blew and so replaced them both. have a screwdriver set in a plastic box. I actually left the box sitting on top of the engine then closed the bonnet . Can't believe I was driving around for a few weeks with a tool kit jammed between the top of the engine and the bonnet. Dread to think what could have happened. Quote Link to comment Share on other sites More sharing options...
stef123 Posted July 29, 2016 Share Posted July 29, 2016 I guess the engine could have dismantled itself? Lol 3 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted July 29, 2016 Share Posted July 29, 2016 Lol, I imagine it was making a bit of a racket, I've found the battery cover makes enough noise if it's not clipped in properly... 1 Quote Link to comment Share on other sites More sharing options...
Pullock Posted July 29, 2016 Share Posted July 29, 2016 1 hour ago, ayrshiredude said: well a few weeks ago I one of my headlight bulbs blew and so replaced them both. have a screwdriver set in a plastic box. I actually left the box sitting on top of the engine then closed the bonnet . Can't believe I was driving around for a few weeks with a tool kit jammed between the top of the engine and the bonnet. Dread to think what could have happened. Look on the bright side, if you needed them, they were there! 1 Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted July 30, 2016 Share Posted July 30, 2016 Why is it on many new cars when trying to take to bits everything breaks Can't imagine a replacement from a scrap-yard wouldn't be too much. Quote Link to comment Share on other sites More sharing options...
Joss max Posted July 30, 2016 Share Posted July 30, 2016 Anything on here like yours James? http://www.parts.loc8apart.co.uk/nav/auto-part/Ford/Fiesta/Interior-Lighting.php Quote Link to comment Share on other sites More sharing options...
ayrshiredude Posted July 30, 2016 Author Share Posted July 30, 2016 3 hours ago, Joss max said: Anything on here like yours James? http://www.parts.loc8apart.co.uk/nav/auto-part/Ford/Fiesta/Interior-Lighting.php Unfortunately not. Looked on eBay etc and only seen one that is £107 which is nearly double what it would cost new. When I got it the end was already broken but long enough to just fit, now that its broken more its too short to fit through unfortunately. Quote Link to comment Share on other sites More sharing options...
Joss max Posted July 30, 2016 Share Posted July 30, 2016 Do You know its part number ? Quote Link to comment Share on other sites More sharing options...
Willy Posted July 31, 2016 Share Posted July 31, 2016 http://eucatparts.com/?action=cat_ford_part&s_id_part=1332742&s_id_model=141 Quote Link to comment Share on other sites More sharing options...
