dentex Posted August 19, 2016 Share Posted August 19, 2016 Hello guys! Little question: why reading from the PCM module requires so much time, compared to the writing operation? Many reported times around 50 minutes. I would expect the exact contrary, as any other memory support. I would love to know what does it have so special. Disclaimer: I've never read the PCM on my Focus. This is what I've always heard around. I used the "as-built" method and then write back in a second or two, when I enabled the CC. Thanks. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted August 19, 2016 Share Posted August 19, 2016 Should take seconds, not 50 mins. Is the switch in the correct position? Quote Link to comment Share on other sites More sharing options...
dentex Posted August 19, 2016 Author Share Posted August 19, 2016 I don't know. I didn't try. As I said, this is just what I've seen reported on various forums from more than one person. I downloaded the "as-built", modified it and wrote it back. So, if I may extrapolate: did you ever try on a recent ELMConfig and PCM reading required just a few seconds? (As other modules do?) Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted August 19, 2016 Share Posted August 19, 2016 This all comes down the the speed of the elm327 interface. You can get cheap copies which support lower speeds or get a good quality unit that's able to acheive the full speed of 50. Quote Link to comment Share on other sites More sharing options...
dentex Posted August 20, 2016 Author Share Posted August 20, 2016 That's fine. I tried a cheap Chinese cable that anyway locked at 500k worked good. All readings and writings I did, took just a few seconds (less than 5 sec). At this point, I'm wondering how much it would have taken to read the PCM configuration... But by now I've already overwritten it with the downloads "as-built", so it doesn't make much sense (I mean: I know already, exactly what's in there). Quote Link to comment Share on other sites More sharing options...
