stevecmax Posted September 30, 2016 Share Posted September 30, 2016 Hoping for some advice My Cmax 1.8 Petrol Duratec developed a fault. Went into limp mode. Called out the RAC as I was miles from home. They said it had Fault code P2110 and coil pack fault code (sorry didnt write that down), He could clear the Coil pack code but not the P2110 code. The next day I plugged my OBD code reader in and was able to clear the codes with no problems. Unfortunately the fault seemed to be getting worse and the vehicle would now only travel approx. 0.5 miles without going into limp mode with the miss fire and ‘Throttle Actuator Control System - Forced Limited RPM’ fault as detailed above. I therefore took the vehicle to my garage where a miss fire on number 1 & 4 cylinders was diagnosed. They swapped the coil packs over to ensure that it was not a coil pack fault but the miss fire continued on cylinder 1 & 4 after the code was cleared (note : the misfire is only on idle). They tested the throttle body and have advised me that there is no fault and therefore it must be the ECU as they are known for being troublesome. The ECU was duly sent to a diagnostic company who stated it was beyond repair and was to earth??? Problem is I need aother ECU. The one I have is &M51-12A650-VC. There are some on eBay but most have different letter suffixes. I can see a VE and a few VC's. My question are the last two letters significant and will i need to get a fusebox etc to go with it. Any help/advice appreciated. Steve Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 23, 2016 Share Posted November 23, 2016 I would be questioning, why the ECU is reported as "beyond repair". This sounds more like an electrical fault, not an ECU fault!!! who removed the ECU? Quote Link to comment Share on other sites More sharing options...
theredfox Posted January 30, 2017 Share Posted January 30, 2017 On 30/09/2016 at 6:38 PM, stevecmax said: Hoping for some advice My Cmax 1.8 Petrol Duratec developed a fault. Went into limp mode. Called out the RAC as I was miles from home. They said it had Fault code P2110 and coil pack fault code (sorry didnt write that down), He could clear the Coil pack code but not the P2110 code. The next day I plugged my OBD code reader in and was able to clear the codes with no problems. Unfortunately the fault seemed to be getting worse and the vehicle would now only travel approx. 0.5 miles without going into limp mode with the miss fire and ‘Throttle Actuator Control System - Forced Limited RPM’ fault as detailed above. I therefore took the vehicle to my garage where a miss fire on number 1 & 4 cylinders was diagnosed. They swapped the coil packs over to ensure that it was not a coil pack fault but the miss fire continued on cylinder 1 & 4 after the code was cleared (note : the misfire is only on idle). They tested the throttle body and have advised me that there is no fault and therefore it must be the ECU as they are known for being troublesome. The ECU was duly sent to a diagnostic company who stated it was beyond repair and was to earth??? Problem is I need aother ECU. The one I have is &M51-12A650-VC. There are some on ebay but most have different letter suffixes. I can see a VE and a few VC's. My question are the last two letters significant and will i need to get a fusebox etc to go with it. Any help/advice appreciated. Steve what was the final out come to your problem no body seems to reply back to these 1 Quote Link to comment Share on other sites More sharing options...
