Oggy02 Posted February 24, 2017 Share Posted February 24, 2017 Hi I have two questions, that hopefully someone will be kind enough to help me with. The first one is the torque setting for the nuts and one bolt, that hold the exhaust manifold to the cylinder head. Not the studs, they are already in. Are the nuts set at the same torque as the one bolt? In the manual it says 54Nm, can someone please clarify or dismiss this figure please. The other issue is regarding the exhaust manifold gasket. As some of you will know, this gasket is not completely flat, like a head gasket. There is a lip on the edges that cover the ports. Does it matter which way the gasket fits, and consequently, which way the lips face? Can post a pic if it helps. Thanks very much. Quote Link to comment Share on other sites More sharing options...
