Mk3 ST Wheel Spacer
D13 HPD 95
As per title really, wanting to stick some spacers on my stock ST wheels, thinking 20mm front and 25mm rear, has anyone done this to a mk3 and know they fit? also do the stock alloys havea recess on the mating hub to allow a little pock from the studs in the hub?
cheers, pictures would help as well :)
Hi Daniel
May i ask why ?
Do you have the stock 18" or the option 19" alloys
These fill the arches very well as it is.
Just be carefull that the tyres do not rub the insides of the arches.
Is your ST lowered or standard
Jamie
stock 18's and its lowered 15/20mm ive had a look and im sure 20mm spacers wouldnt course any rubbing, now its lower just need filling out a little more
Hi Daniel
Ok fair enough, Would the tyres or rims rum on the suspension strut or cables etc.
If no then go ahead and try it, but im sure someone more experianced will be along shortly :-)
Wider track at the back may help at least
Jamie
I have 20mm spacers front and back on my MK3. No rubbing at all, looks great too. Going for 25mm in the rear soon though. Needs a little more poke.
Before:
Thanks KPG now im hooked and want to do that to my st.
was there anything else you need to do for that ?
Where should i get the spacers from
are the wheel studs long enough
Jamie
I got these:
http://www.ebay.co.uk/itm/400995199803
Everything needed is included in the kit. Just get two kits, 1x front and 1x rear. Just can use the 'make offer' function on eBay, i got two sets for £105 :)
I recommended 20F and 25R. Needs a little more poke in the rear. Just wish my front suspension height was about an inch lower :(
Sent from my HTC 10 using Tapatalk
kpg - do you know if the stock ST alloys have the room behind them for the hub studs to still fit ok? yours looks good but different alloys to mine
Im pretty sure your alloys would be fine. I was recommended those spacers by the guys over at STOC. There's at least 5/6 STs like yours with the same kit and no problems reported.
Sweet he's out of stock on the 20's but will order up when available :)
i am have 20mm spacers for sale £35 delivered on my mk2 diesel, should fit mk3 st
Messaged you mate
