Sausages Posted January 20, 2018 Share Posted January 20, 2018 Hi all, I have just bought a 2007 smax and I am now finding all the problems I hadn't noticed when I test drove it. Who would have thought to test the horn! Anyway . I can get the horn to sound when bridged across the relay connections and I have power at the horn switch in the steering wheel. I have tested the relay with power from a battery charger and it switches. Its just when i press the horn i have no power at the relay. Any ideas would be greatly appreciated. Regards Sausages Quote Link to comment Share on other sites More sharing options...
Sausages Posted January 20, 2018 Author Share Posted January 20, 2018 Forgot to say I also have fault code b1c55. Quote Link to comment Share on other sites More sharing options...
Micro Posted January 23, 2018 Share Posted January 23, 2018 On 1/20/2018 at 7:45 PM, Sausages said: Hi all, I have just bought a 2007 smax and I am now finding all the problems I hadn't noticed when I test drove it. Who would have thought to test the horn! Anyway . I can get the horn to sound when bridged across the relay connections and I have power at the horn switch in the steering wheel. I have tested the relay with power from a battery charger and it switches. Its just when i press the horn i have no power at the relay. Any ideas would be greatly appreciated. Regards Sausages When you say the relay "switches" have you physically tested for continuity between the switched contacts or are you just hearing the click? They can still click (the electromagnetic coil is still working), but the contacts make no contact inside it. Does anything else not work on the steering wheel if you have any steering wheel controls? Any ABS/ESP lights? Quote Link to comment Share on other sites More sharing options...
Sausages Posted January 24, 2018 Author Share Posted January 24, 2018 Hi Micro, thanks for getting back to me. I have bench tested the relay and it switches and allows current to flow. I have no clicking when it is in the fuse box. It suprised me to find I have power at the horn switch as I thought it should just be a negative feed to the relay. I do have a positive feed into the relay but when the horn is pressed no negative so the relay doesn't throw. If I supply a negative feed to the relay the horn does sound. From my description you can see I'm a bit of a novice, I hope it makes sense. Any ideas would be appreciated. Sausages Quote Link to comment Share on other sites More sharing options...
Sausages Posted January 24, 2018 Author Share Posted January 24, 2018 Forgot to say all other steering wheel controls are working. I do have an abs fault but I don't think it's connected. Its wss failure on the front left I think. Quote Link to comment Share on other sites More sharing options...
