BP2411 Posted May 13, 2018 Share Posted May 13, 2018 Hello everyone, my car is due an oil & filter change, I usually use 5w30 fully synthetic Petronas oil but eurocarparts is bringing up fully & semi synthetic for my reg and semi is significantly cheaper. Which do I use? Also anyone here use a magnetic sump plug or is it just a scam? Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted May 13, 2018 Share Posted May 13, 2018 Fully synthetic as far I know, the magnetic sump plug won't do any harm to have one but it's not really necessary 1 Quote Link to comment Share on other sites More sharing options...
BP2411 Posted May 13, 2018 Author Share Posted May 13, 2018 Thanks for the fast reply! Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted May 13, 2018 Share Posted May 13, 2018 Having magnetic oil drain plugs have saved us from catastrophic failures on various pieces of equipment (compressors, gearboxes etc.). They just give you a heads up that if you carry on going then you will blow the engine/box up. Fix it sooner and you won't have the gaping hole in the side. Quote Link to comment Share on other sites More sharing options...
BP2411 Posted May 17, 2018 Author Share Posted May 17, 2018 Does anyone know what size sump plug and washer is on this engine? Quote Link to comment Share on other sites More sharing options...
kingsblue Posted May 17, 2018 Share Posted May 17, 2018 The sump plug is 13mm on petrol models, I guess the diesel models are the same, make sure you use a six sided socket so yo get a better grip on it. Quote Link to comment Share on other sites More sharing options...
