Sign in to follow this
Turbo1
Mk7 1.0 Ecoboost AC not working
2014 - AC light on , regassed, fuse seems ok, slight noise when turning on/off (presume compressor working), fan works. Owned for 6months never worked.
Any ideas???
If it had gas before the recharge we take it has not worked after I would need to know what the static pressures are and then the hi and low pressures with AC switched on
with AC if the Compressor clutch is spinning you need to know the pressures so ask the garage that recharged it last ?
on the ecoboost its on the off side lower front but you will see two large hose / pipes going to it what every engine you have
Cheers....will have to find out the pressures from the mobile ac service used today....what you thinking?
I will think about it when you give me the pressures as that is where you start with ac
that will tell me what the system is doing if any this is working etc
  Only 75 emoji are allowed.
