HighHo Posted June 17, 2019 Share Posted June 17, 2019 Can anyone recommend someone/company to do a pcm firmware recovery? I was doing a flash when my battery died (annoying at about 95% complete), 100% my bad, I was following a guide that said the upload would be a lot quicker, but I ignored my instinct. Ignoring all the above and me being an idiot, I can't write it using elmconfig. Can anyone either help recover, or recommend someone/somewhere that can? Thanks, Alex (HighHo) Quote Link to comment Share on other sites More sharing options...
HighHo Posted June 18, 2019 Author Share Posted June 18, 2019 I will likely try replacing the whole ECU unit, could anyone tell me where it located on the MK2.5 1.8 petrol 2008. Assume it will be the same place as the diesel versions, behind the front of the passenger wheel arch, but wanted to double check as it seems like a pain! Quote Link to comment Share on other sites More sharing options...
iantt Posted June 18, 2019 Share Posted June 18, 2019 Yep same place. 1 Quote Link to comment Share on other sites More sharing options...
HighHo Posted June 18, 2019 Author Share Posted June 18, 2019 Nice one, thanks for confirming. Quote Link to comment Share on other sites More sharing options...
HighHo Posted June 22, 2019 Author Share Posted June 22, 2019 Just a quick update (not sure it's that interesting to others), new ECU is fitted, programmed and all working. Replacing the ECU unit wasn't as bad as I thought it would be, luckily there were no security bolts on mine. I think you could remove the plastic wheel arch cover without removing the wheel (but probably worth it for the space). Reprogrammed using elmconfig, thought I might have a duff unit as the pcm wouldn't read, but just needed to program the keys first in FORScan so the immobiliser passed. Hopefully allowed, but also just want to say thanks to a chap called Enda from endtuning.com was extremely helpful in providing advice on possibly recovering my original ECU (and may have been able to repair it). 1 Quote Link to comment Share on other sites More sharing options...
HighHo Posted September 11, 2019 Author Share Posted September 11, 2019 Just thought I would post a quick update on this, I had to reflash the PCM module as the tyre size was out. On diesel cars I believe you can just update the vid block. On petrol however you need to flash it fully, as there's not much info on this. I just thought I would list the steps I used. Make sure you have a charger to the battery to be safe (my original mess up and block size at 64 instead of auto). 1. Backup pcm firmware and config. 2. Flash the firmware back, you will be asked twice if you want to load the vid block, select no on both. Leave the block size as auto (mine used 1024, if 64 for example it will take ages). (21 mins) 3. Once flashed you can now load pcmconfig and make any changes if needed and apply. (2-3 mins). 1 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted September 18, 2019 Share Posted September 18, 2019 On 9/11/2019 at 9:17 PM, HighHo said: Just thought I would post a quick update on this, I had to reflash the PCM module as the tyre size was out. On diesel cars I believe you can just update the vid block. On petrol however you need to flash it fully, as there's not much info on this. I just thought I would list the steps I used. Make sure you have a charger to the battery to be safe (my original mess up and block size at 64 instead of auto). 1. Backup pcm firmware and config. 2. Flash the firmware back, you will be asked twice if you want to load the vid block, select no on both. Leave the block size as auto (mine used 1024, if 64 for example it will take ages). (21 mins) 3. Once flashed you can now load pcmconfig and make any changes if needed and apply. (2-3 mins). Fair play in posting back mate, your pain may well help out someone else in the future! Quote Link to comment Share on other sites More sharing options...
