ikarma70 Posted March 10, 2010 Share Posted March 10, 2010 Hi all,long time no post! Can anyone tell me where the reverse sensor/switch is on a 1.25 zetec motor pls(photo's would be helpful too for anyone else for future reference)? My reverse light has packed up and I'm sure its the sensor,its not the bulb as my rear lights work ok and it has been an intermittant problem as when the reverse is engaged,the light goes on but let go off the gearstick,it goes out. thanks in advance. Andy Quote Link to comment Share on other sites More sharing options...
CAR PARTS EXPRESS Posted March 10, 2010 Share Posted March 10, 2010 There are 2 different types but its usually a square plastic switch about 2" x 3" in size , black and white fitted on the box.if not it will be a metal circular switch down on the front of the box Quote Link to comment Share on other sites More sharing options...
ikarma70 Posted March 10, 2010 Author Share Posted March 10, 2010 There are 2 different types but its usually a square plastic switch about 2" x 3" in size , black and white fitted on the box.if not it will be a metal circular switch down on the front of the box Is that near the oil pressure switch bottom r/h side of engine? Quote Link to comment Share on other sites More sharing options...
CAR PARTS EXPRESS Posted March 10, 2010 Share Posted March 10, 2010 no on the gearbox itself not the engine Quote Link to comment Share on other sites More sharing options...
ikarma70 Posted March 12, 2010 Author Share Posted March 12, 2010 did ford update the gearbox from the 2 wire switch to a sensorbox unit? Quote Link to comment Share on other sites More sharing options...
CAR PARTS EXPRESS Posted March 12, 2010 Share Posted March 12, 2010 Yes that is the square block I mentioned Quote Link to comment Share on other sites More sharing options...
ikarma70 Posted March 12, 2010 Author Share Posted March 12, 2010 Yes that is the square block I mentioned thanks very much bud, my mates going to check all the fuses and connections before i start spending on the new parts:) Quote Link to comment Share on other sites More sharing options...
CAR PARTS EXPRESS Posted March 13, 2010 Share Posted March 13, 2010 If you got the square type fitted its £30.11 + £3.00 delivery. 0191 4200168 Quote Link to comment Share on other sites More sharing options...
ikarma70 Posted March 15, 2010 Author Share Posted March 15, 2010 If you got the square type fitted its £30.11 + £3.00 delivery. 0191 4200168 can get a new genuine ford ib5 switch on eBay for £27 and they are only 12 miles from me but thanks anyway :) Quote Link to comment Share on other sites More sharing options...
