Tomsfiesta Posted July 29, 2019 Share Posted July 29, 2019 Hello all. I have a standard 1.25, 2006 ,Style model fiesta. I'm wanting to make it sound a little louder, but nothing to louder, but just more grr..if that makes sense. Will an induction kit do that or am I best going down the exhaust route? Quote Link to comment Share on other sites More sharing options...
zain611 Posted July 29, 2019 Share Posted July 29, 2019 I don't think an induction kit will do much or even anything so probably an exhaust is a reliable mod to get some noise. Quote Link to comment Share on other sites More sharing options...
Tomsfiesta Posted July 30, 2019 Author Share Posted July 30, 2019 Ok cool. Any suggestions? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted July 30, 2019 Share Posted July 30, 2019 A proper induction kit will give you a bit more noise on a petrol, it's a gentle burble at idle with a sort of sucking 'bwaaaaar' noise as you build the revs, try running the engine with the airbox lid off briefly and you'll hear the difference. They are usually classed as a performance mod though so can be a pain to insure when you're young. Exhausts give a lot more choice of noise, from tinny, buzzy 'bee in a can' right through to rumbly, bassy 'brown noise' tones. Ideally you'd want somewhere between the two lol. Personally I like the rasp of a Milltek but they don't make them for the 1.25. You'd probably have to risk a cheap backbox unless you went for a custom system and could then chose exactly what you want. Same problem with insurance though, so definitely check before buying anything. Quote Link to comment Share on other sites More sharing options...
Tomsfiesta Posted July 30, 2019 Author Share Posted July 30, 2019 Thank u. I'll take the air box off first and give that a go to see how it sounds. With the induction kits I've seen them priced from £40-£100. Am I best going with something like a k&n or will the cheaper kits do the same job? Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 30, 2019 Share Posted July 30, 2019 27 minutes ago, Tomsfiesta said: Thank u. I'll take the air box off first and give that a go to see how it sounds. With the induction kits I've seen them priced from £40-£100. Am I best going with something like a k&n or will the cheaper kits do the same job? A straight swap panel filter from Green Cotton Performance or K&N will work well rather than a mushroom filter, Also leave the induction box but remove the snorkel part Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 30, 2019 Share Posted July 30, 2019 Good value though https://www.ebay.co.uk/itm/57-0686-K-N-57i-Induction-Kit-FORD-FIESTA-MK6-1-2L-1-4L-1-6L-KN-Intake-Kits/264409136070?epid=249061247&hash=item3d90033bc6:g:mhIAAOSwwi5dJxk5 Need to avoid heavy rain and floods with the mushroom filter but cheaper than it should be Quote Link to comment Share on other sites More sharing options...
Tomsfiesta Posted July 30, 2019 Author Share Posted July 30, 2019 Sounds like the filter route is a lot simpler and less faffing. I will explore the different options. So swapping the standard filter for a k&n or Green Cotton would make it sound better? Or would I need to adjust the air box too to get the most out of it? Quote Link to comment Share on other sites More sharing options...
Tomsfiesta Posted August 4, 2019 Author Share Posted August 4, 2019 By removing the pipe will that lower my fuel economy? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 4, 2019 Share Posted August 4, 2019 If you want noise, you need to remove the airbox...upgrade panel filters are a bit pointless in my experience. You will notice a drop in MPG because you'll drive it a bit harder to hear the noise lol. Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 4, 2019 Share Posted August 4, 2019 2 minutes ago, TomsFocus said: If you want noise, you need to remove the airbox...upgrade panel filters are a bit pointless in my experience. You will notice a drop in MPG because you'll drive it a bit harder to hear the noise lol. Alternatively dropping the sump should get it popping and banging 🤣 Quote Link to comment Share on other sites More sharing options...
DAN@ADRIAN FLUX Posted August 4, 2019 Share Posted August 4, 2019 Hi. If you do have any issues with insurance at all then please feel free to drop me a line. Regards, Dan. 1 Quote Link to comment Share on other sites More sharing options...
