ItsOnlyMe Posted November 14, 2019 Share Posted November 14, 2019 Hi, My indicator stalk sticks or doesn't engage properly when I push it to indicate to the right. I think it has muck/dust in it. Can I use silicon spray to get it moving or do I need to get a new one. Can the old one be refurbished? Has anybody else any experience of this? Thanks in advance, Kerrie. Quote Link to comment Share on other sites More sharing options...
isetta Posted November 14, 2019 Share Posted November 14, 2019 if mine I would probably try spraying wd40 into it. I don't think silicone spray would be good in the electrical contacts. I once took one apart because it was stuck on high beam and wouldn't dip. the switch felt ok the way it clicked but the headlights did not change. I found a small bit had broken off inside so I bought a 2nd hand replacement on eBay for not much money which was fine. these switches are designed not to be taken apart. I think if you are very careful you might be able to get it apart and clean/lube parts and get it back together but they are very fiddly. Quote Link to comment Share on other sites More sharing options...
