Arkhangelsk1989 Posted January 16, 2020 Share Posted January 16, 2020 Hello, I was driving home from work and my car suddenly cut out and the red light at the top of the instrument cluster was flashing and a message saying engine system fault, high engine temperature showed up. I got the car home and disconnected and reconnected the battery and now the car starts fine. The engine was barely even warm as I only have a 2 minute drive too work so the high engine temperature is confusing. One thing that I will say is that the rear brakes are seizing up so if that's got anything too do with it I don't know but I'm getting that sorted tomorrow. I plugged in an obd2 scanner and got 2 fault codes: P0324 P0325 The car is a Ford fiesta mk6 zetec s 2007 with 49000 miles. Cheers for any help Quote Link to comment Share on other sites More sharing options...
zain611 Posted January 17, 2020 Share Posted January 17, 2020 Hopefully someone will help knowing what those codes indicate 👍 1 Quote Link to comment Share on other sites More sharing options...
Fiesta1.25 Posted January 17, 2020 Share Posted January 17, 2020 Both codes are related to the knock sensor circuit, have a read at this see if there’s something in there that helps. Keep us up to date with any findings.https://www.honestjohn.co.uk/forum/post/index.htm?t=89317 2 Quote Link to comment Share on other sites More sharing options...
Arkhangelsk1989 Posted January 17, 2020 Author Share Posted January 17, 2020 I have had a look at the connections today and all seems fine. I have it booked in for a proper inspection as I'm concerned about what happened the other day with it cutting out so it will put my mind at rest. Cheers 1 Quote Link to comment Share on other sites More sharing options...
Paulkp Posted January 17, 2020 Share Posted January 17, 2020 Weird...... I have a 2007 1.6 petrol Zetec S too.... And earlier this week, first thing in the morning, went to start it, red flashing LED and it came up with "High engine temperature", no start. Turned it all off, tried again and the same. Turned it off again, waited about a minute, than all started OK. Later I went through the in built data display menu to look for fault codes, can't remember the exact codes, but "Corrupt Data" I think was the outcome. Now in "Wait and See" mode. 1 Quote Link to comment Share on other sites More sharing options...
Arkhangelsk1989 Posted January 17, 2020 Author Share Posted January 17, 2020 Very weird, my engine was barely even getting warm then it just cut out and I lost steering. Managed too get it on the drive and it still wouldn't start or anything so I disconnected and reconnected the battery and it fires up straight away with no lights on the dash or anything. Those codes I had are related too the knock sensor but I doubt that would cause the engine too cut out. Very strange 😐 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted January 18, 2020 Share Posted January 18, 2020 18 hours ago, Paulkp said: Weird...... I have a 2007 1.6 petrol Zetec S too.... And earlier this week, first thing in the morning, went to start it, red flashing LED and it came up with "High engine temperature", no start. Turned it all off, tried again and the same. Turned it off again, waited about a minute, than all started OK. Later I went through the in built data display menu to look for fault codes, can't remember the exact codes, but "Corrupt Data" I think was the outcome. Now in "Wait and See" mode. Did you use a diagnostic tool to check any fault codes? Could check the knock sensor to be safe 👍 Quote Link to comment Share on other sites More sharing options...
Paulkp Posted January 18, 2020 Share Posted January 18, 2020 No I did not - I lent it to my brother a few weeks ago, and it is 60 miles away! I only used the dash display. (I really ought to ask him for it back!) In my case the engine did not even turn over - just red flashing LED, and overtemp. Quote Link to comment Share on other sites More sharing options...
Arkhangelsk1989 Posted January 19, 2020 Author Share Posted January 19, 2020 Hello, quick update, my car just did the same thing again while I was on my way back from Derby, luckily it cut out on a quiet street. I called the RAC too come and have a look and it turned out the be the ecu earth cable on the negative battery terminal was lose because the threads were stripped on the actual bolt. The bolt on the right is where it normally should be but the chap from the RAC move it too the bolt on the left RAC are absolute saviours and they deserve more credit than they get 1 Quote Link to comment Share on other sites More sharing options...
