Morty1977 Posted May 31, 2020 Share Posted May 31, 2020 There was no water coming out of my 67 plate focus windscreen washer managed to get the pump out and the filter was a right mass of sticky slime!! Works a treat now! Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 31, 2020 Share Posted May 31, 2020 Eurgh! Which screenwash do you use? 1 Quote Link to comment Share on other sites More sharing options...
Morty1977 Posted May 31, 2020 Author Share Posted May 31, 2020 This stuff Quote Link to comment Share on other sites More sharing options...
Morty1977 Posted May 31, 2020 Author Share Posted May 31, 2020 Wont be using it again😂 1 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 31, 2020 Share Posted May 31, 2020 I would recommend that even if you use pre-mixed wash fluid, adding a pint of water will thin it down a bit without really reducing the effectiveness but will help to avoid clogging and sludge.With concentrated wash add an extra pint too, your wash pumps will work far better. I add some distilled vinegar at times so that any scale is dissolved (also beneficial against salt smearing in winter). Sent from my SM-G965F using Tapatalk 1 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 31, 2020 Share Posted May 31, 2020 Lol, definitely one to avoid then! Surprised a Michelin product would do that but I reckon the 'rain shield' is some sort of wax that's separated out and sludged at the bottom. 1 1 Quote Link to comment Share on other sites More sharing options...
Morty1977 Posted May 31, 2020 Author Share Posted May 31, 2020 Could be I only used it really water down too!! 2 Quote Link to comment Share on other sites More sharing options...
2 Fast 4 U Posted May 31, 2020 Share Posted May 31, 2020 2 hours ago, Stoney871 said: ........I add some distilled vinegar at times so that any scale is dissolved (also beneficial against salt smearing in winter). If you use distilled water to mix with the screen wash you don't have to ad distilled vinegar Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 31, 2020 Share Posted May 31, 2020 If you use distilled water to mix with the screen wash you don't have to ad distilled vinegarMaybe, but you don't get that "I've had chips" smell [emoji6]Sent from my SM-G965F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 31, 2020 Share Posted May 31, 2020 Chips are the last thing I want on the windscreen! 2 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 31, 2020 Share Posted May 31, 2020 Sent from my SM-G965F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Morty1977 Posted June 1, 2020 Author Share Posted June 1, 2020 🤣🤣👍 1 Quote Link to comment Share on other sites More sharing options...
