Andyr55 Posted May 11, 2021 Share Posted May 11, 2021 Can anyone confirm if the 12 v socket on mk4 Focus is live without the ignition? I don’t have anything to try it with but was considering a solar trickle charger. Quote Link to comment Share on other sites More sharing options...
Wino Posted May 11, 2021 Share Posted May 11, 2021 My battery monitor switches off when I lock the car if I leave it plugged in. Never thought to look if it switches on when I just unlock it though without pressing the ignition button ( Start button). Quote Link to comment Share on other sites More sharing options...
Wino Posted May 11, 2021 Share Posted May 11, 2021 40 minutes ago, Andyr55 said: Can anyone confirm if the 12 v socket on mk4 Focus is live without the ignition? I don’t have anything to try it with but was considering a solar trickle charger. If your thinking along the same lines as me then you can get them to charge directly via the OBD port. Quote Link to comment Share on other sites More sharing options...
StephenFord Posted May 11, 2021 Share Posted May 11, 2021 1 hour ago, Andyr55 said: Can anyone confirm if the 12 v socket on mk4 Focus is live without the ignition? I don’t have anything to try it with but was considering a solar trickle charger. My previous car only had an 'ignition controlled' 12v supply, so I added a permanent live 12v socket especially for charging. However, I found a solar trickle charge of very limited use as the battery still use to fail if left for any length of time! Quote Link to comment Share on other sites More sharing options...
Wino Posted May 11, 2021 Share Posted May 11, 2021 Had been looking at the AA one the other week. Some reviews said they had the odd error notification after using it though so was put off by that but it would be a feasible way if topping up the battery whilst its sat in the works carpark for 10 hours a day. Quote Link to comment Share on other sites More sharing options...
StephenFord Posted May 11, 2021 Share Posted May 11, 2021 59 minutes ago, Wino said: Had been looking at the AA one the other week. Some reviews said they had the odd error notification after using it though so was put off by that but it would be a feasible way if topping up the battery whilst its sat in the works carpark for 10 hours a day. Look for one with the highest watt output you can afford, all the rest are Mickey Mouse! I bought a 'sealey' 5w charger but it never had a strong enough output to properly keep battery charged. 1 Quote Link to comment Share on other sites More sharing options...
Wino Posted May 11, 2021 Share Posted May 11, 2021 23 minutes ago, StephenFord said: Look for one with the highest watt output you cab afford, all the rest are Mickey Mouse! I bought a 'sealey' 5w charger but it never had a strong enough output to properly keep battery charged. I did some research tbh ( That's a first lol) 12v with 10w is the recommendation but its finding one with an OBD port connector. The AA ones I've come across are 1.8w and 4.8w respectively so don't think either are up to the job. Halfords do one buts mainly for leisure batters @ 6.8w and only connects direct to battery terminals. Thanks for the heads up 👍 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted May 11, 2021 Share Posted May 11, 2021 Hi just to confirm, I have tested all 3 of the 12V sockets on my Mk4 Focus and they all switch OFF with the ignition. You would have thought in this day and age that they would be programmable. I can't remember which car I had some 30 years ago but there were two spaces in the fuse box for the 'cigar ligter' and you put a fuse in either Ignition controlled or permanent live. A simple but good idea at the time. Quote Link to comment Share on other sites More sharing options...
Wino Posted May 11, 2021 Share Posted May 11, 2021 3 minutes ago, unofix said: Hi just to confirm, I have tested all 3 of the 12V sockets on my Mk4 Focus and they all switch OFF with the ignition. You would have thought in this day and age that they would be programmable. I can't remember which car I had some 30 years ago but there were two spaces in the fuse box for the 'cigar ligter' and you put a fuse in either Ignition controlled or permanent live. A simple but good idea at the time. Im beginning to wonder if the OBD port would still work if the car was switched off and locked or would that still need to have the ignition on or would it still work due to the solar charger itself being plugged into the OBD port 🤔 Quote Link to comment Share on other sites More sharing options...
unofix Posted May 11, 2021 Share Posted May 11, 2021 Hold the Bus !! I've just been told that you might be able to programme the 12V sockets to stay on using ForScan. I need to investigate this, has anyone information, can it be done ? Just found this:- https://forscan.org/forum/viewtopic.php?t=9176 so maybe it can be done with a Focus Quote Link to comment Share on other sites More sharing options...
stevejwalford Posted May 11, 2021 Share Posted May 11, 2021 I have a MK2 Facelift focus, my 12v sockets are always live. I am sure I read somewhere that the fuse box has 3 pins available for the 12v sockets. You only use two pins at a time but in one position the 12v sockets are controlled by the ignition and in the other position the 12v sockets are live all the time... Quote Link to comment Share on other sites More sharing options...
StephenFord Posted May 11, 2021 Share Posted May 11, 2021 Just now, stevejwalford said: I have a MK2 Facelift focus, my 12v sockets are always live. I am sure I read somewhere that the fuse box has 3 pins available for the 12v sockets. You only use two pins at a time but in one position the 12v sockets are controlled by the ignition and in the other position the 12v sockets are live all the time... Well, that would have saved me a bit of hassle LOL I had an 'ignition' controlled socket installed in my Focus as the factory one was permanently live and I assumed I had no other option! Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 12, 2021 Share Posted May 12, 2021 19 hours ago, unofix said: I can't remember which car I had some 30 years ago but there were two spaces in the fuse box for the 'cigar ligter' and you put a fuse in either Ignition controlled or permanent live. A simple but good idea at the time. Possibly a Peugeot/Citroen? The old 306s had a shunt fuse that could be moved from from switched live to perm live. Quote Link to comment Share on other sites More sharing options...
unofix Posted May 12, 2021 Share Posted May 12, 2021 Hi Tom, I've only ever owned/driven Ford, Vauxhall and Jaguar so I guess it has to have been one of those. I remember at the time being quite pleased that I could set the cigar lighter to be ignition controlled. 1 Quote Link to comment Share on other sites More sharing options...
