Lambelli Posted January 24, 2023 Share Posted January 24, 2023 Hi, I have fitted an Xtrons head unit into my 2008 focus. the problem I am having is the milage display stays on when ignition is off, I know it's meant to stay on for a 20 minutes or so but the segment that displays the fuel range usually goes out. but mine is staying fully on for over an hour, this started when I connected the ACC wire on the radio. The harness supplied with the head unit only had yellow and black connected with the ACC wire seprate and capped of and thats how I installed it and the radio switched on and off and worked ok untill I switched off and and switched on the followheing day when it would go through the whole boot up routine again not instantly coming on. I was advised to connect the ACC wire to a switched live so I wired it into the plug along with yellow and black and thats when the display started staying fully on, if I remove the ACC wire the display goes back to normal i.e the range segment goes off instantly and the and rest after 20 minuts. I just want my head unit to switch on without always going through the bootup routine as it should, and the display to shut down normaly. any help would be greatly received thanks. Quote Link to comment Share on other sites More sharing options...
unofix Posted January 24, 2023 Share Posted January 24, 2023 Connect a diode in series with the ACC wire which at the moment is 'Back Feeding' the aux circuit. Use something like a 1N4004 diode. https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=144360982756&_sacat=0 2 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted January 24, 2023 Share Posted January 24, 2023 6 minutes ago, unofix said: Connect a diode in series with the ACC wire which at the moment is 'Back Feeding' the aux circuit. Use something like a 1N4004 diode. The depths of your knowledge never cease to amaze me! 1 1 Quote Link to comment Share on other sites More sharing options...
VFR800 Posted January 25, 2023 Share Posted January 25, 2023 11 hours ago, StephenFord said: The depths of your knowledge never cease to amaze me! We need to know if it works first!!! 😉 Quote Link to comment Share on other sites More sharing options...
unofix Posted January 25, 2023 Share Posted January 25, 2023 1 hour ago, VFR800 said: We need to know if it works first!!! 😉 You doubt me !!!! 🤣 🤣 Of course you are correct, it may not fix the problem, I have assumed the OP has connected the constant live and the switched live the right way round. 🤔 1 Quote Link to comment Share on other sites More sharing options...
Lambelli Posted January 25, 2023 Author Share Posted January 25, 2023 Hi thanks for the reply. I emailed the manufacturer and got the folling reply. 1):For correct operation the stereo needs to be powered as described here Yellow Wire - 12V permanent Red Wire - 12V switched from the ignition (ACC) Black - Ground Most commonly this is resolved by "Reversing the Lives" this is simply removing the RED and YELLOW wire and exchanging their position in the ISO . Each pin has a small tab that can be depressed with a small flat screwdriver allowing you to remove the pin from the ISO connection, when removed press the tab out so it will lock into place when reinserted. Please do not hesitate to contact us should you have any further questions. Kind regards, Gabby so I did swap the to lives as suggested didn't make blind bit of difference. so I looked at the can decoder box and saw it is for ford mondeo. I removed the box and everything went back to normal I.e mileage display works as it should, I just don't have steering wheel controls volume up down ect. I will try the diod though. Quote Link to comment Share on other sites More sharing options...
troy45 Posted January 25, 2023 Share Posted January 25, 2023 This sounds similar to issues I had when I fitted android tablet head unit couple of years back - it was keeping the car awake while connected and couldn’t lock the doors. Removing the canbus box sort of fixed it but without steering wheel controls working etc Thought it was a problem with the box but I’d missed some info about disconnecting one of the connections maybe ACC it was on its own plug & socket in the loom. My unit boots up each time I put the ignition on but it’s not an issue for me Quote Link to comment Share on other sites More sharing options...
Lambelli Posted January 25, 2023 Author Share Posted January 25, 2023 Hi troy45, my previous head unit a cheap (£68) chinees job gave me trouble by draining the battery over night, I was told to cut the Acc wire and fixed it retained the can box and steering wheel controls still worked. I only upgraded to Xtrons because the cheapy only had 1gb memory and couldnot install anything. Quote Link to comment Share on other sites More sharing options...
mjt Posted January 25, 2023 Share Posted January 25, 2023 I presume you're aware that Xtrons is Chinese also. Quote Link to comment Share on other sites More sharing options...
Lambelli Posted January 25, 2023 Author Share Posted January 25, 2023 Yes I'm aware, but it is streets ahead of the no name one I had, 2x32gb much better screen and more responsive, apart from the can bus decoder Issue I'm happy with it. Quote Link to comment Share on other sites More sharing options...
Lambelli Posted January 27, 2023 Author Share Posted January 27, 2023 Ok Guys, Diode and solder seal wire connectors arrived this morning. Will be doing the job tomorrow will let you know if successful or not. 3 Quote Link to comment Share on other sites More sharing options...
unofix Posted January 27, 2023 Share Posted January 27, 2023 Don't forget which way round the Switched live and the constant live is, you might have to swap them. 1 Quote Link to comment Share on other sites More sharing options...
Lambelli Posted January 27, 2023 Author Share Posted January 27, 2023 will make sure to have the switched and constant in the original positions. I did switch them around didn't make any difference to the operation of the head unit so will switch back. Quote Link to comment Share on other sites More sharing options...
Lambelli Posted January 28, 2023 Author Share Posted January 28, 2023 Unofix you cracked it! it works😄 Thanks for the advice its fixed, no more head unit in and out, its been out more times than jordans upper torso. 2 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted January 28, 2023 Share Posted January 28, 2023 2 minutes ago, Lambelli said: Unofix you cracked it! it works😄 Thanks for the advice its fixed, no more head unit in and out, its been out more times than jordans upper torso. I refer my honourable member to the comment I made earlier (about Unofix) "The depths of your knowledge never cease to amaze me!" He certainly knows his onions, and diodes, glad you got sorted... 1 2 Quote Link to comment Share on other sites More sharing options...
