driver rear door not working
Very sorry guys, really didn't know what else to call it 😂
Anyway been at it again for a good 10 minutes and still couldn't get it out, really need to find the loose wire.
Just had another good look at the door and I think I might be able buy the whole loom wire and just replace it all. I think it might take couple hours.
Again, if anyone has a better idea on what I should do then I'm all ears.
  • Replies 85
  • Views 6.4k
  • StephenFord
    StephenFord
    Can you clarify, "won't work". Does the handle work?Is the handle jammed?  Does it not operate with the central locking? Does it open from the outside, but not the inside? C'mon buddy, help us out her
  • Stoney871
    Stoney871
    Spam. Blocked.
  • There are 13 different locks/windows/speaker combinations for your year and model. The good news is that 7 of them were not used in the UK but that still leaves 6 different wiring harnesses to chose f
Apologies unifox, only just seen your first post regarding replacing.
Should I just get that one I linked?
Just compare the wire i have in door to the one I linked and my mine has alot more wires so will need to look around for one.
Just had a look on ebay and they all seem less wires than mine, am i missing something?
This is mine:
Now, that's the 2nd time this week I've seen the inside of a Mk2 door, mine getting the hinge strap replaced...
Not all of them have electric rear windows.
Yeah that is the wires I am missing, the ones for electric windows
I have sent ford an email, waiting fir them to get back to me.
At the meantime I will keep looking around
i have managed to source one from a breaker for 47.99 posted. does that sound good price?
Can you afford it? Do you want it? Do you need it? If answer is yes to all, then go get it...
i have just purchased it, il update this thread on how i get on. hopefully nothing gets in the way.
Ok guys, the wire has turned up now.
Question is what is the best way to replace the wires?
My original plan was to try feed the wires through where the rubber boots are but then I noticed another connector which I believe goes inside the door.
I have seen some bolts that are around the edges and just wondering if taking them off would be my best option?
I just don't want any surprises like something will fall out and I can't put it back in or something like that.
Hope someone can help please
i am guessing i will need to take the door off?
No !!
3 minutes ago, unofix said:
No !!
many thanks for the reply
but i have a feeling i will need to take the inner panel off? there are some bolts around the edges so i undo them then i can just take all the wires out?
Yes, that is correct.
Yes 👍
Yes 👍
Awesome!! Thank you 🙂
just one more question and il crack on it.
Do I need to tape the window on up/closed position first? I keep thinking the window might slip down.
There is no reason for you to remove the window regulator and therefore the window will not slip down.
Ok thank you again
I will take the panel off tomorrow and crack on 🙂
13 hours ago, froggy8 said:
Ok thank you again
The window regulator is connected to that panel.  You will need to lower the window, unbolt it from the regulator through holes behind foam pads, then tape it to the top of the door, before being able to remove the panel & regulator together.
hhmmmm...... thank you, just thinking how that can be done as there is no power going to that door at all 😞
ok i have an idea, since i am replacing the whole wire, i was thinking about cutting the motor wire and connecting it to a battey but theres alot of wires connected to the motor though, can anyone tell me which 2 wires i need to connect to a battery please?
if i had to guess, i would have thought its the bottom 2 wires ( brown and black)
Good idea.  I don't know which wires it is though, and wouldn't really like to just guess.
The alternative would be to plug the new loom in between the door pillar and window motor.  Just let it hang in front of the panel for now.
that is the best idea using my new wire, many thanks again tom 🙂
ok so i plugged ecerything in for the window, didnt work so i inspected the plug and found out that the 2nd slot didnt have any pins in it.
have took pictures:
