driver rear door not working
Focus Mk2 2006 Fusebox location.
  • Replies 85
  • Views 6.4k
  • StephenFord
    StephenFord
    Can you clarify, "won't work". Does the handle work?Is the handle jammed?  Does it not operate with the central locking? Does it open from the outside, but not the inside? C'mon buddy, help us out her
  • Stoney871
    Stoney871
    Spam. Blocked.
  • There are 13 different locks/windows/speaker combinations for your year and model. The good news is that 7 of them were not used in the UK but that still leaves 6 different wiring harnesses to chose f
The fuse numbers are pressed into the GEM below each fuse.  But you do need very good eyesight to see them! :laugh:
Many thanks guys, I will have a proper good look at each fuses when I get chance.
Change in fuse designation
With the introduction of the new GEM generation
7M5T-14A073-XX, the fuse designations have
been changed.
Fuse 81 becomes fuse 120
been changed.
Brilliant!
That saves me looking through them all.
Thank you
Ok, have checked the fuse and it looked OK but changed it anyway and tested the central locking and still doesn't work so maybe perhaps it's a different wire altogether.
update guys
all fixed now 🙂 many thanks guys 🙂
does anyone know how to reset the window as double tap doesnt go on its own, i have to keep hold of the window switch for it to go all the way down or up.
27 minutes ago, froggy8 said:
does anyone know how to reset the window..
Try this, sadly he's American, but I think the procedure is the same for UK cars...
Many thanks mate 😊
2 hours ago, froggy8 said:
Many thanks mate 😊
yep that worked 🙂
only problem i have is putting the window switch back on the door card which is proving very challenging 😞
i managed to click in one side but the other side on the left where the buttons are, doesnt want to click in.
do i need to use double sided tape?
yep that worked 🙂
