driver rear door not working
that cant be normal as then what is the purpose of the second plug that goes in there?
  • Replies 85
  • Views 6.4k
  • StephenFord
    StephenFord
    Can you clarify, "won't work". Does the handle work?Is the handle jammed?  Does it not operate with the central locking? Does it open from the outside, but not the inside? C'mon buddy, help us out her
  • Stoney871
    Stoney871
    Spam. Blocked.
  • There are 13 different locks/windows/speaker combinations for your year and model. The good news is that 7 of them were not used in the UK but that still leaves 6 different wiring harnesses to chose f
I admire your tenacity! Long before this stage, I would have taken it to a proper spark to get fixed. Still, look at the learning curve you're enjoying 😀
who said i was enjoying it? 😄
but yeah, i really do like to learn things 🙂
i am actually considering buying another door now 😄
I'm considering buying a 'chinese', it's Dr Who night and Eurovision 🤣
Are you sure that is the correct harness, it looks like one for a car without electric rear windows.
I thought that at first but the plug that goes in the window motor/ regulator is there.
I double checked the old plug that I broke and that only had about 6 wires too.
This is the wire i bought:
The picture of the single plug is for the electric window.
I have took the wire/harness that I broke off:
As you can see, there is also about 6 wires there.
Ok, I have took the regulator out and kept pushing down on the cog where the regulator/ motor was and have managed to roll the window down 🙂
Sorry it was stupid idea
ok then, after i managed to take the inner panel off, i connected all the wiring. central locking and electric window still not worked but the speaker did.
so will try find another wire loom.
There are 13 different locks/windows/speaker combinations for your year and model. The good news is that 7 of them were not used in the UK but that still leaves 6 different wiring harnesses to chose from. They are not interchangeable as you have already found out.
If you are lucky the original Ford wiring harness part number label will still be on your original harness. See if you can find it and post a few photos of the label here (photos of both sides of the label).
good idea with the part number, hopefully will still be on.
thankfully the loom label was still there 🙂
You probably didn't disconnect the battery before playing around with the wiring so I would suggest you check fuse 81 (20A) is good
Thank you but I have ripped bit of the wire now so when I can find another loom then I will disconnect the battery this time.
Could you tell me where is the 81 fuse is please? I've found the diagram for my fuse box but none of them is showing 81
You need this wiring harness 3M5T-14240-AFP  from eBay:-
https://www.ebay.co.uk/itm/274825354649?
2 minutes ago, unofix said:
You need this wiring harness from eBay:-
Many thanks for that 🙂
I have just bought it now.
how did you find one so cheap? That one what i bought was 50.
It's in the fusebox under the glovebox.  Not the one in the engine bay.
I have had a search for my diagram and when i found it, all the fuses was over 100.
In many cases the 2006 model has a different fusebox to that shown in the users handbook.
