MrPickle Posted May 26 Share Posted May 26 Hi there, I have a 2023 Ford Focus ST line vignale with Sync 4. I have started the car up today and I am receiving all these messages. It appears literally all the electronic assistance systems are down and no working. I can’t book in as it’s a bank holiday. Do we have any tech whizzes in here that might be able to assist? Have reset the battery to no avail. many thanks in advance! 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted May 26 Share Posted May 26 Use a multimeter and measure the battery State Of Charge about one hour after parking. I expect you will find it less than 60% Use a smart charger and recharge the battery for at least 12 hours (even if the charge is showing full). Remeber to connect the negative lead to the car chassis and NOT to the battery negative terminal. Lastly do not reset the BMS unless you have fitted a brand new battery. Quote Link to comment Share on other sites More sharing options...
MrPickle Posted May 26 Author Share Posted May 26 10 minutes ago, unofix said: Use a multimeter and measure the Battery State Of Charge about one hour after parking. I expect you will find it less than 60% Use a smart charger and recharge the battery for at least 12 hours (even if the charge is showing full). Remeber to connect the negative lead to the car chassis and NOT to the battery negative terminal. Lastly do not reset the BMS unless you have fitted a brand new battery. Hi there, Thanks for the advice. I am not a car person by any stretch of the imagination - do I need to remove the entire battery to charge it? Thanks 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted May 26 Share Posted May 26 No. The battery should remain in the car and fully connected. Do not disconnect the battery. Use a Smart battery charger like the Maypole Connect the positive lead direct to the battery positive terminal. Connect the negative lead to a chassis earth point, not the battery. Charge for at least 12 hours, even if the charger is indicating fully charged. It is not possible to over charge the battery with a Smart charger. Quote Link to comment Share on other sites More sharing options...
MrPickle Posted May 26 Author Share Posted May 26 5 minutes ago, unofix said: No. The battery should remain in the car and fully connected. Do not disconnect the battery. Use a Smart battery charger like the Maypole Connect the positive lead direct to the battery positive terminal. Connect the negative lead to a chassis earth point, not the battery. Charge for at least 12 hours, even if the charger is indicating fully charged. It is not possible to over charge the battery with a Smart charger. Hey, thats so helpful thanks so much! In terms of a chassis earth point, can you spot one in this pic? If not can I send a full pic of under the bonnet? I 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted May 26 Share Posted May 26 It's not on your photo. It is nearer the front, towards the headlight Quote Link to comment Share on other sites More sharing options...
unofix Posted May 26 Share Posted May 26 This is my car:- Quote Link to comment Share on other sites More sharing options...
MrPickle Posted May 26 Author Share Posted May 26 11 minutes ago, unofix said: This is my car:- Hey! Thanks - a couple pics of mine attached, I can’t spot anything in similar location to yours but could it be this one by the washer fluid on the left? Quote Link to comment Share on other sites More sharing options...
unofix Posted May 26 Share Posted May 26 Oh the things that Ford get up to so they can save a few pence 🙄 You can connect to the negative cable as it joins to the car bodywork. 1 Quote Link to comment Share on other sites More sharing options...
MrPickle Posted May 26 Author Share Posted May 26 20 minutes ago, unofix said: Oh the things that Ford get up to so they can save a few pence 🙄 You can connect to the negative cable as it joins to the car bodywork. haha I was wondering why they are all so different! in that case I read that as being here on my car… Quote Link to comment Share on other sites More sharing options...
MrPickle Posted May 27 Author Share Posted May 27 17 hours ago, unofix said: Use a multimeter and measure the Battery State Of Charge about one hour after parking. I expect you will find it less than 60% Use a smart charger and recharge the battery for at least 12 hours (even if the charge is showing full). Remeber to connect the negative lead to the car chassis and NOT to the battery negative terminal. Lastly do not reset the BMS unless you have fitted a brand new battery. So an update - 12.3 is what it currently sits at. Regardless, it’s plugged in charging now to see if we have a difference or not Quote Link to comment Share on other sites More sharing options...
MrPickle Posted May 29 Author Share Posted May 29 On 5/26/2024 at 7:53 PM, unofix said: Oh the things that Ford get up to so they can save a few pence 🙄 You can connect to the negative cable as it joins to the car bodywork. Hey, thanks for all your help. Quick update: battery was fine - 12.4v+ Couldn't get in to the ford garage for a few weeks. Auto electrician came out, error code with the ABS system. Was checked and is all completely fine so could have been something blocking one of the other sensors that triggered it all off. ABS system reset and all is fixed! 1 Quote Link to comment Share on other sites More sharing options...
