mrwonderful Posted December 1, 2010 Share Posted December 1, 2010 A water loss registeredd a couple of weeks ago. Put the car into garage after checking no radiator or hose faults and expansion bottle level stayed at proper level. Garage said could not find anything.Water still enters inside drivers side. Quote Link to comment Share on other sites More sharing options...
LiamZetec Posted December 1, 2010 Share Posted December 1, 2010 It's highly likely that part of the seal between your door is damaged and may need replacing, inspect it to see if you can see any splits or cuts in it anywhere around the door arch. Liam Quote Link to comment Share on other sites More sharing options...
artscot79 Posted December 1, 2010 Share Posted December 1, 2010 door seal or check the engine bay it can get in from the bulkhead b est way is to trace the water there will be visible signs lift drivers carpet and insulation and have a good look Quote Link to comment Share on other sites More sharing options...
Wizz Posted December 1, 2010 Share Posted December 1, 2010 If you have aircon, make sure the drain hose has not come loose on the passenger side of the bulkhead. I had it happen to me twice, leaving water in the passenger floor well. Quote Link to comment Share on other sites More sharing options...
