archie2000 Posted February 18, 2011 Share Posted February 18, 2011 How easy is it to self fit rear parking sensors to a mk4 Mondeo? I have seen various kits available on the internet, and they don't look too complicated, and the saving in cost if I fit them myself is pretty good. Also, can anyone recommend any particular ones please? Quote Link to comment Share on other sites More sharing options...
Thunderguts Posted February 18, 2011 Share Posted February 18, 2011 Very easy hardest part was locating the wire to reverse lights I put a post up last year Quote Link to comment Share on other sites More sharing options...
archie2000 Posted February 18, 2011 Author Share Posted February 18, 2011 Very easy hardest part was locating the wire to reverse lights I put a post up last year Great stuff, thanks for responding. I'll locate your previous post. Cheers Archie Quote Link to comment Share on other sites More sharing options...
Thunderguts Posted February 18, 2011 Share Posted February 18, 2011 These ones are the ones i got they come in various colours and include a drill bit. Look at your rear bumper and under it is a plastic strip this is where ford mount these and these fit a treat. Look behind and you will see the spaces where they go. Drill there and use washing up liquid when you fit sensors. On the left hand side of the boot remove the panel to access the light wireing/fuse box. look for a brown/green wire you will need to splice onto this for your live feed to sensors, connect the earth to a suitable point. I fed the sensor wires through the grommet at the bottom of the spare wheel well(didn't want to drill metalwork yet) used duct tape to protect wires plus some old carpet. Connect the wires to control unit and then i put the speaker under the plastic parcel shelf supports about 5 inches from the rear seats. took about 1 hour start to finish. They work a treat and for £14.99 compared to frauds prices. FYI i chose the matt black, I also fitted a switch to them so I have the option to turn them off if I want to! ebay Quote Link to comment Share on other sites More sharing options...
btmaldon Posted February 18, 2011 Share Posted February 18, 2011 Ive got the same plastic strip on the rear of the Focus. While I was fitting the reversing sensors I also fitted a camera to it. To think Ford want £200 for these when you can by them for between £10 and £20. Quote Link to comment Share on other sites More sharing options...
Thunderguts Posted February 18, 2011 Share Posted February 18, 2011 Thats any main dealer for you! Fitted ambient light in the week, cost under £6, ford price quoted today was £88, plus they were not sure if it is possible!!!!! Pic of sensors Quote Link to comment Share on other sites More sharing options...
archie2000 Posted February 18, 2011 Author Share Posted February 18, 2011 Brill, thanks for your input guys. I picked up my 59 plate Titanium earlier tonight ( :D whoop whoop) so I will order them this week and fit next weekend. Cheers Archie Quote Link to comment Share on other sites More sharing options...
archie2000 Posted February 22, 2011 Author Share Posted February 22, 2011 Hi Thunderguts, I have located the brown/green wire (well, it is more green with a brown stripe) in the bottom left hand corner of the boot. This is connected to the fuse box. I am a bit confused however, as in an earlier post, you say that it is best to make the connection at the top where the rubber hose connects to the tailgate. Which is best? Cheers archie *Edit* Sussed it now, it's not the wire by the fusebox. That is a bigger gauge wire than the one in the tailgate, so not the same one. I actually managed to get a connection behind the side shelf panel at the top of the boot so no need to feed the cable down the rear pillar. Biggest problem was getting a decent earth connection, but managed that eventually. Quote Link to comment Share on other sites More sharing options...
Thunderguts Posted February 24, 2011 Share Posted February 24, 2011 When I did mine I was not sure where the wires ran when they entered the boot! Otherwise I'd of connected to the same one you have. But job done they work so can't be bad as for earth I managed to find a screw that had a good earth had a c connector so losened the screw and job done! Quote Link to comment Share on other sites More sharing options...
Sheepdisease Posted November 16, 2012 Share Posted November 16, 2012 Can someone please provide photos of the installation? I am desperate to get mine fitted. I also want to know the safest/tidiest way to connect this system to the reverse light cable please! Quote Link to comment Share on other sites More sharing options...
Finbarr Posted December 17, 2013 Share Posted December 17, 2013 These ones are the ones i got they come in various colours and include a drill bit. Look at your rear bumper and under it is a plastic strip this is where ford mount these and these fit a treat. Look behind and you will see the spaces where they go. Drill there and use washing up liquid when you fit sensors. On the left hand side of the boot remove the panel to access the light wireing/fuse box. look for a brown/green wire you will need to splice onto this for your live feed to sensors, connect the earth to a suitable point. I fed the sensor wires through the grommet at the bottom of the spare wheel well(didn't want to drill metalwork yet) used duct tape to protect wires plus some old carpet. Connect the wires to control unit and then i put the speaker under the plastic parcel shelf supports about 5 inches from the rear seats. took about 1 hour start to finish. They work a treat and for £14.99 compared to frauds prices. FYI i chose the matt black, I also fitted a switch to them so I have the option to turn them off if I want to! ebay Thunderguts, Thank you for a great post. I don't want to sound like an idiot, but what is the washing up liquid for? Thanks. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 17, 2013 Share Posted December 17, 2013 Hi Lee, I suspect it will probably be just as a lubricant? Quote Link to comment Share on other sites More sharing options...
Finbarr Posted December 17, 2013 Share Posted December 17, 2013 Thank you. That makes sense. Quote Link to comment Share on other sites More sharing options...
always fords Posted June 10, 2015 Share Posted June 10, 2015 These ones are the ones i got they come in various colours and include a drill bit. Look at your rear bumper and under it is a plastic strip this is where ford mount these and these fit a treat. Look behind and you will see the spaces where they go. Drill there and use washing up liquid when you fit sensors. On the left hand side of the boot remove the panel to access the light wireing/fuse box. look for a brown/green wire you will need to splice onto this for your live feed to sensors, connect the earth to a suitable point. I fed the sensor wires through the grommet at the bottom of the spare wheel well(didn't want to drill metalwork yet) used duct tape to protect wires plus some old carpet. Connect the wires to control unit and then i put the speaker under the plastic parcel shelf supports about 5 inches from the rear seats. took about 1 hour start to finish. They work a treat and for £14.99 compared to frauds prices. FYI i chose the matt black, I also fitted a switch to them so I have the option to turn them off if I want to! ebay I had reverse sensors fitted to my last Mondeo by Jennings ford they also fitted a towbar at the same time, and at that time they mentioned they had to fit the reverse sensors at a higher position in the Bumper than ford usually fitted as they would interfere with the towbar sending out wrong signals . This they did and I hadn't any issues with false signals at all . I hope this Helps anyone who Decides to fit Sensors with a Towbar Quote Link to comment Share on other sites More sharing options...
