Tomo2482 Posted April 7, 2011 Share Posted April 7, 2011 Hi, I have a Fiesta TD 2001 and my battery continually drains overnight unless I disconnect the negative lead. I have had a new alternator, recon starter (tested today its fine), and I am on my second battery. If I leave it connected when I turn the key all the lights come on and the speedo needle goes round but no noise or cranking engine. My garage and a auto electrician can find no drain or fault. Can anyone help all help appreciated. Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 7, 2011 Share Posted April 7, 2011 Hi, I have a Fiesta TD 2001 and my battery continually drains overnight unless I disconnect the negative lead. I have had a new alternator, recon starter (tested today its fine), and I am on my second battery. If I leave it connected when I turn the key all the lights come on and the speedo needle goes round but no noise or cranking engine. My garage and a auto electrician can find no drain or fault. Can anyone help all help appreciated. hi mate this link might help you did me :) Quote Link to comment Share on other sites More sharing options...
Tomo2482 Posted April 17, 2011 Author Share Posted April 17, 2011 hi mate this link might help you did me :) Thanks for that I will have a look !!!!!!! Quote Link to comment Share on other sites More sharing options...
Tomo2482 Posted April 17, 2011 Author Share Posted April 17, 2011 hi mate this link might help you did me :) Just tried my small 12v tester and only thing drawing a small amount of power is the clock its on all the time so I have disconnected it will see if it starts in the morning !!!!! Quote Link to comment Share on other sites More sharing options...
Tomo2482 Posted May 1, 2011 Author Share Posted May 1, 2011 Just tried my small 12v tester and only thing drawing a small amount of power is the clock its on all the time so I have disconnected it will see if it starts in the morning !!!!! Just disconnected 3 amp violet ecu fuse in engine bay and drain has gone down from 3 amp to 1.3 amp car starts and drives fine ? confused ???? Quote Link to comment Share on other sites More sharing options...
