machinerysteve Posted December 7, 2008 Share Posted December 7, 2008 Hi just wondered if anyone out there knows the correct procedure for changing the air con and alternator drive belts on a 1.6 zetec mk 2 focus, there are no signs of any adjustment methods etc, regards, Steve. Quote Link to comment Share on other sites More sharing options...
getfocusworking Posted December 10, 2008 Share Posted December 10, 2008 Hi just wondered if anyone out there knows the correct procedure for changing the air con and alternator drive belts on a 1.6 zetec mk 2 focus, there are no signs of any adjustment methods etc,regards, Steve. I should think it's the same as the Mk1 Focus. The tensioner is a self adjust tensioner. Put a spanner around the small tensioner pulley ( not the top idler pulley ) pull back release belt, fit new belt pull back again slip over tensioner job done. Some times it's better to put the belt over the tensioner and slip it over the crankshaft pulley when pulling the tensioner back. Hope this helps. Quote Link to comment Share on other sites More sharing options...
machinerysteve Posted December 12, 2008 Author Share Posted December 12, 2008 I should think it's the same as the Mk1 Focus.The tensioner is a self adjust tensioner. Put a spanner around the small tensioner pulley ( not the top idler pulley ) pull back release belt, fit new belt pull back again slip over tensioner job done. Some times it's better to put the belt over the tensioner and slip it over the crankshaft pulley when pulling the tensioner back. Hope this helps. Hi thanks but its not the same as the mk1, there is no movable idler all the pulleys are fixed solid, no adjustment, I have never seen a set up like this just seems a bit strange, regards, Steve. Quote Link to comment Share on other sites More sharing options...
mmafighterlinc896 Posted December 12, 2008 Share Posted December 12, 2008 Hi just wondered if anyone out there knows the correct procedure for changing the air con and alternator drive belts on a 1.6 zetec mk 2 focus, there are no signs of any adjustment methods etc,regards, Steve. hi if its anything like the td models from underneathof the car there should be an adjuster on a 10mm on mine it was located just to the right of the crankshaft pulley and it is a bit awkward to get to, and it does depend what engine you have in it for its year. Quote Link to comment Share on other sites More sharing options...
spudgun Posted January 18, 2009 Share Posted January 18, 2009 Hi thanks but its not the same as the mk1, there is no movable idler all the pulleys are fixed solid, no adjustment, I have never seen a set up like this just seems a bit strange, regards, Steve. Your right Steve. Mine has developed a metallic "chirp" from cold with all the electric goodies on. I changed an alternator because of it. Anyway, they now use stretch belts on alternator and air con drives. The kit from Ford including 2 belts and the tools to fit is 50 odd quid plus vat Quote Link to comment Share on other sites More sharing options...
