irl-06lx Posted February 10, 2012 Share Posted February 10, 2012 See the attached photo. I removed the gear know, and then removed the leatherette trim which included the grey square surround. There is a bit of give in the small (1cm wide on the right) black trim immediately outside the grey square at the bottom of the leatherette trim. Does anyone know how to remove this? It's simply for cleaning reasons, nothing else. Cheers Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 10, 2012 Share Posted February 10, 2012 The silver bit is called the gear lever gaiter trim and the other bit is called the surround trim. I take it you mean that you have successfully removed the gaiter trim and are trying to remove the surround trim? To remove the surround trim just pull the back of it up to unclip it (the back being the bit that faces you). Quote Link to comment Share on other sites More sharing options...
irl-06lx Posted February 11, 2012 Author Share Posted February 11, 2012 greatly appreciated Quote Link to comment Share on other sites More sharing options...
Pidu Posted February 11, 2012 Share Posted February 11, 2012 Any info how to do it in car with automatic transmission? Quote Link to comment Share on other sites More sharing options...
ijustwantafile Posted May 4, 2012 Share Posted May 4, 2012 The silver bit is called the gear lever gaiter trim and the other bit is called the surround trim. I take it you mean that you have successfully removed the gaiter trim and are trying to remove the surround trim? To remove the surround trim just pull the back of it up to unclip it (the back being the bit that faces you). I'm thinking of fitting a push button start and this seems to be an easy way of fitting my hand under to get at the current 12v port out to fit the button. can anyone provide advice of how to "unclip" it. I don't want to damage anything! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 4, 2012 Share Posted May 4, 2012 Wide bladed screwdriver with tape around it. Push under the edge and twist carefully. Quote Link to comment Share on other sites More sharing options...
Smokingmonke91 Posted March 21, 2020 Share Posted March 21, 2020 (edited) On 2/11/2012 at 10:49 PM, Pidu said: Any info how to do it in car with automatic transmission? You'll have to use a minus screw driver and pry upwards from the silver trim piece on the bottom right corner closest to the + sign. I have attached a photo. As in the below link. Due to certain unknown reasons the link is not being attached so I had to paste it here. https://drive.google.com/file/d/1MLyI31KVMTW7heiJvTTK_UEV25OlL_Q1/view?usp=drivesdk 聽 https://drive.google.com/file/d/1MKiELnmUYNqguOahsnRct1_F__0ek6ml/view?usp=drivesdk 聽 Edited March 21, 2020 by Smokingmonke91 Link is not being attached for some reason Quote Link to comment Share on other sites More sharing options...
StephenFord Posted March 21, 2020 Share Posted March 21, 2020 Crikey, that question was posed 8 years ago LOL I've been waiting with baited breath ever since, thank goodness it's finally answered 馃ぃ 1 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted March 21, 2020 Share Posted March 21, 2020 1 hour ago, StephenFord said: Crikey, that question was posed 8 years ago LOL I've been waiting with baited breath ever since, thank goodness it's finally answered 馃ぃ Any plans for what your going to do with your life now that you have finally overcome this ?聽 The handbrake gator perhaps 馃槀 1 1 Quote Link to comment Share on other sites More sharing options...
PepZ Posted May 3, 2021 Share Posted May 3, 2021 4F27E. How you take them other bits out? I have code p0815. Thats the only problem. Need too look at wiring etc Quote Link to comment Share on other sites More sharing options...
