Whitters Posted March 26, 2012 Share Posted March 26, 2012 Good Evening, I had the fronts pads changed on my MK4 Mondeo today and since then I've had a Tyre Pressure Malfunction. The garage have read the fault codes and it says its auto reset. Is this normal and will it recover once I've done a few miles. I hate having warning lights lite on the dash as its all seems very expensive to turn the off. Thanks Phil Quote Link to comment Share on other sites More sharing options...
Whitters Posted April 1, 2012 Author Share Posted April 1, 2012 After nearly a week of having a Malfunction showing on the dash I had to do something about it. I've tried deflating and over inflating the tyre to activate the TPMS alarm and then put the tyre pressures back to the correct pressures. i've also tried taking the wheels off to activate the TPMS. All to no avail. In the end I did the manly thing of losing my rag and disconnting the battery for 15 minutes. The only thing went through my mind once it had been disconnected was did I have the radio code. Ooops. Low and behold it worked. Silence in the car no lights on the dash, for some reason a radio that still works. Never asked me for a code. Winner. Regards Phil :D Quote Link to comment Share on other sites More sharing options...
Jamesfry Posted October 28, 2019 Share Posted October 28, 2019 Hi there. i have an s max 2010 titanium x. I’ve just got home from the tyre shop and have the same ‘tyre monitor malfunction’ alarm coming on constantly. The tyre was over inflated to 38psi when it should have been 34psi. Any Ideas as to what to do next?? Quote Link to comment Share on other sites More sharing options...
TheBadger66 Posted October 31, 2019 Share Posted October 31, 2019 On 10/28/2019 at 8:34 PM, Jamesfry said: Hi there. i have an s max 2010 titanium x. I’ve just got home from the tyre shop and have the same ‘tyre monitor malfunction’ alarm coming on constantly. The tyre was over inflated to 38psi when it should have been 34psi. Any Ideas as to what to do next?? Hi, Not sure if this is right for your car but you can reset them..... https://www.drivingtesttips.biz/dashboard-warning-lights/ford-dashboard-warning-lights/ford-mondeo/tyre-pressure-sensor-reset.html Quote Link to comment Share on other sites More sharing options...
dermot prior Posted September 15, 2020 Share Posted September 15, 2020 On 3/26/2012 at 7:45 PM, Whitters said: Good Evening, I had the fronts pads changed on my MK4 Mondeo today and since then I've had a Tyre Pressure Malfunction. The garage have read the fault codes and it says its auto reset. Is this normal and will it recover once I've done a few miles. I hate having warning lights lite on the dash as its all seems very expensive to turn the off. Thanks Phil ive a mondeo with a similer problem replaced 4 bran new sensors the problem is still flashing up Quote Link to comment Share on other sites More sharing options...
