Mark Akers Posted December 13, 2012 Share Posted December 13, 2012 Hi All, I'm new here and only been driving 3 weeks ago, passed my test in November and also have no idea about cars! I'm running an '03 plate Mk6 Fiesta, 1.4 Zetec - Fully standard apart from wheels / springs. (not too bad for a first car!) Anyhow, recently, since the weather started getting colder, on the odd occasion my car has been going VERY slow & "AEC Failure" has appeared on the dash but when I switch my car off/on it's fine. Also, tonight, I was driving and going down a hill, nothing un-usual, doing 45 Mph and I heard a "click" from my clutch and my clutch pedal appeared to lose any compression and do nothing. It has raised higher than the other two pedals and when pressed down does nothing and almost falls down. I managed to get the car towed home, but it is not also stuck in reverse! I can not tow the car to a garage as I can not get it out of reverse so I'm all round at a loss really. Was just wondering if this could be a simple problem or a large thing? Any feedback is much appreciated! Thanks, Mark Quote Link to comment Share on other sites More sharing options...
Navarro93 Posted December 14, 2012 Share Posted December 14, 2012 Don't know what AEC failure is, but if it's lost power but then recovers when you switch off then on again, I'd suggest it's probably some sort of "limp mode" to protect the engine (You'll probably need a diagnostics check to find out what is wrong) As far as being stuck in reverse is concerned, the gear selector linkage is on the front of the gearbox on a Mk6 Fiesta (I know, I have one, same year as yours, but the Black edition) It's under a black plastic cover. If you take the cover off, you should be able to move the selector about and pop the car out of reverse so you can get it towed Good luck! Quote Link to comment Share on other sites More sharing options...
Mark Akers Posted December 14, 2012 Author Share Posted December 14, 2012 That's great - thanks for the reply! I'm not to clued up on cars so don't suppose you'd be able to post a pic of where it is under the bonnet? & yep, been told to get the AEC Failure checked out by connecting it to a code reader so I shall be getting it all done together (once I manage to get it out of reverse!) Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 14, 2012 Share Posted December 14, 2012 look at the rear of your clutch pedal, i will put money on it that the hydraulic actuator part has detached from the pedal. it will clip back on but it will work its way off again eventually Quote Link to comment Share on other sites More sharing options...
Mark Akers Posted December 14, 2012 Author Share Posted December 14, 2012 Thanks for the reply. However too late now:( Got it too a garage and they've said it will be £250 because it needs a new Hydraulic something or other. Mark Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 14, 2012 Share Posted December 14, 2012 Thanks for the reply. However too late now:( Got it too a garage and they've said it will be £250 because it needs a new Hydraulic something or other. Mark oh dear, sounds like you are being ripped off to be honest mate. it can be fixed without the need to replace it all you need is a good cable tie or even a small jubilee clip. IIRC there is a guy on eBay selling serated washers to fit them for a couple of quid. ok a slight rip off for a little clip but.. http://www.ebay.co.uk/itm/FORD-FIESTA-MK6-CLUTCH-PEDAL-REPAIR-KIT-LOCKING-WASHER-/181041816205?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AFiesta&hash=item2a26eee28d Quote Link to comment Share on other sites More sharing options...
Mark Akers Posted December 15, 2012 Author Share Posted December 15, 2012 http://www.ebay.co.u...=item2a26eee28d Oh yes I was looking at these but have never seen them before so wasn't to sure what it was! I'd much rather pay £5 then what I'm going to have to lol but I suppose the good outcome is, I'll have a full new clutch system so that shouldn't go again and I'm guessing it hasn't been changed within its 9 years. Mark Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 15, 2012 Share Posted December 15, 2012 Oh yes I was looking at these but have never seen them before so wasn't to sure what it was! I'd much rather pay £5 then what I'm going to have to lol but I suppose the good outcome is, I'll have a full new clutch system so that shouldn't go again and I'm guessing it hasn't been changed within its 9 years. Mark well you will have a new master cylinder, but yes i would like to think you wont have any bother with it again. Quote Link to comment Share on other sites More sharing options...
flying clutchman Posted December 16, 2012 Share Posted December 16, 2012 I once fitted a new master cylinder (supplied by customer) to a fiesta which had done this and it lasted 2 months before it did the same thing. I normally take off the pedal and drill a 2mm hole in the post which the arm hooks onto and put a split-pin through it. Basically a design fault. Quote Link to comment Share on other sites More sharing options...
