Daysleeper101 Posted April 21, 2013 Share Posted April 21, 2013 Hi guys, Here's my story Just left the MOT station on Friday,having flew through it,mechanic even congratulated me on having such a sound car lol Got about half a mile down the road when the engine just died ,got mechanic from MOT station too have a look.....no joy.got RAC to look ....no joy.got towed home. When I turn the key I get nothing,not a thing,fuel pump doesn't prime, starter doesn't turn . Immobiliser light flashes constant every 2seconds,nothing changes when ignition is left on,all fuses are fine everything works on the car,everything earthed.factory fitted alarm and immobiliser ANYONE HELP PLEASE... Quote Link to comment Share on other sites More sharing options...
btmaldon Posted April 21, 2013 Share Posted April 21, 2013 Just check that the cut out switch hasn't activated. Can't remember where the reset button is, but normally in one of the footweels near the front bottom corner of the doors. There should be a flap with a button behind it. If its not that it could be a fuse. Quote Link to comment Share on other sites More sharing options...
Daysleeper101 Posted April 21, 2013 Author Share Posted April 21, 2013 Just check that the cut out switch hasn't activated. Can't remember where the reset button is, but normally in one of the footweels near the front bottom corner of the doors. There should be a flap with a button behind it. If its not that it could be a fuse. Thanks mate I've checked these things,there ok It's as if the key isn't recognised and the starter and fuel pump have been cut off. Quote Link to comment Share on other sites More sharing options...
FOCA Posted April 21, 2013 Share Posted April 21, 2013 You may have to get a Ford main dealer or an auto locksmith to reset it/ re code it before it will start again Do you have an OBD2 code reader? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 21, 2013 Share Posted April 21, 2013 Sounds like an immobiliser fault to me. Quote Link to comment Share on other sites More sharing options...
Daysleeper101 Posted April 21, 2013 Author Share Posted April 21, 2013 You may have to get a Ford main dealer or an auto locksmith to reset it/ re code it before it will start again Do you have an OBD2 code reader? No mate I don't have a reader Sounds like an immobiliser fault to me. I'm thinking immo fault Do you know if an ECU change is needed and am I right in thinking its behind the glovebox Quote Link to comment Share on other sites More sharing options...
