david295 Posted October 16, 2013 Share Posted October 16, 2013 I am having to drive around with air con on all the time to stop windows steaming up, what is causing them to steam up constantly Quote Link to comment Share on other sites More sharing options...
jamesm182 Posted October 16, 2013 Share Posted October 16, 2013 Do you have anything damp in the car? Quote Link to comment Share on other sites More sharing options...
000 Posted October 16, 2013 Share Posted October 16, 2013 Its happening in my new zetec S... really flipping annoying. Dont know if the windows need a good clean or what but its really bugging me. Only happening when its wet outside I'll add.. Quote Link to comment Share on other sites More sharing options...
Clarky2013 Posted October 16, 2013 Share Posted October 16, 2013 Exact same problem today for me in my new zs Quote Link to comment Share on other sites More sharing options...
david295 Posted October 16, 2013 Author Share Posted October 16, 2013 Do you have anything damp in the car?no Quote Link to comment Share on other sites More sharing options...
Mordey Posted October 16, 2013 Share Posted October 16, 2013 Make sure you have the air recirculation off so only fresh enters the cabin or you will just keep the damp air going round in circles. Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted October 16, 2013 Share Posted October 16, 2013 I have same problem i find flicking the heater round so it vents on to the window gets rid if it over time but still comes back :/ Quote Link to comment Share on other sites More sharing options...
jamesm182 Posted October 16, 2013 Share Posted October 16, 2013 Its happening in my new zetec S... really flipping annoying. Dont know if the windows need a good clean or what but its really bugging me. Only happening when its wet outside I'll add.. I must admit when it's wet my car does seem to get a little steamy sometimes. I guess that's just the damp in the air. Quote Link to comment Share on other sites More sharing options...
btmaldon Posted October 16, 2013 Share Posted October 16, 2013 This company does an eco in car de-humidifier. Might be worth a try: http://scripts.affiliatefuture.com/AFClick.asp?affiliateID=322181&merchantID=5043&programmeID=13173&mediaID=126086&tracking Quote Link to comment Share on other sites More sharing options...
Willy Posted October 16, 2013 Share Posted October 16, 2013 Water can get into the car quite easily when it's raining like when you open the door during a downpour, there's water all over you and the inside of the door. This water will evaporate when the car warms up but will stay inside the car invisible until it cools and condenses. Do this a few times and you'll find it hard to get rid off. Quote Link to comment Share on other sites More sharing options...
wullie1515 Posted October 16, 2013 Share Posted October 16, 2013 Check the headcloth at the rear close too the boot....it is a common place for a water ingress/leak.... The water leaks in from a seal thats around a wiring loom, if you open the boot and see the black covered up wiring check the seal, and check headcloth isn't wet, if its wet it will most likely be leaking at the wiring seal, had a couple of 2013 zetec s fiestas like this in my work Quote Link to comment Share on other sites More sharing options...
Clarky2013 Posted October 16, 2013 Share Posted October 16, 2013 Just checked mine, was driving a lot in the rain all day and steamed up a lot, the headcloth is dry but the seal isnt exactly tight Quote Link to comment Share on other sites More sharing options...
Gary Watt Posted October 17, 2013 Share Posted October 17, 2013 Hello Happens to me too but have to say that it happened with my previous car also, VW Polo. Must be something to due with temperature out side and inside of the car. Not a real issue on cold days for me. Gary 1 Quote Link to comment Share on other sites More sharing options...
JackieR Posted October 17, 2013 Share Posted October 17, 2013 Me also. My last Fiesta was a nightmare. Air-Con on .... Air-Con off ..... and it went on like this until I got to where I was going !!! I even bought something that was supposed to stop the inside misting up .... RUBBISH ! I usually run with the window down a wee bit anyway, but on rainy days that's not very handy. That's another thing with Fiestas .... the water drips off the roof and in the window like you wouldn't believe. Drives me nuts ! Bought the wind deflectors for the windows, but when we tried to fit them, the windows wouldn't work, so they have been abandoned in to the loft !! Waste of money .... UNLESS ... anyone have fitting tips ????? :D Quote Link to comment Share on other sites More sharing options...
wullie1515 Posted October 17, 2013 Share Posted October 17, 2013 You need too reset the windows.....use only the first click on the switch and hold up and once it reaches the top, keep holding you should hear a little click within a second...thats the window reset for the fully closed position...do the same for going downwards and use only the first click of the switch 1 Quote Link to comment Share on other sites More sharing options...
david295 Posted October 18, 2013 Author Share Posted October 18, 2013 You need too reset the windows.....use only the first click on the switch and hold up and once it reaches the top, keep holding you should hear a little click within a second...thats the window reset for the fully closed position...do the same for going downwards and use only the first click of the switch How would this cause the windows to steam up. 1 Quote Link to comment Share on other sites More sharing options...
JackieR Posted October 18, 2013 Share Posted October 18, 2013 You need too reset the windows.....use only the first click on the switch and hold up and once it reaches the top, keep holding you should hear a little click within a second...thats the window reset for the fully closed position...do the same for going downwards and use only the first click of the switch Thank you .... i'll try that. I don't know if it will make that much difference, but being a smoker, I like to have the window down, and on wet days, i'm constantly mopping up water coming dripping down from the roof and coming in the window. It's not like it's WIDE open, it's just enough to flick out of ! Bad habit I know, but we all have at least one !!! Cheers, Jackie :) Quote Link to comment Share on other sites More sharing options...
JackieR Posted October 18, 2013 Share Posted October 18, 2013 How would this cause the windows to steam up. It doesn't .... I went a wee bit off topic and asked about fitting the Climair wind deflectors ! Quote Link to comment Share on other sites More sharing options...
wullie1515 Posted October 18, 2013 Share Posted October 18, 2013 How would this cause the windows to steam up. I was referring too the question about wind deflectors.... Quote Link to comment Share on other sites More sharing options...
wullie1515 Posted October 18, 2013 Share Posted October 18, 2013 Haha! Yeap we all have out habbits....mines is a heavy foot if someone decides too fly past me lol 1 Quote Link to comment Share on other sites More sharing options...
JackieR Posted October 18, 2013 Share Posted October 18, 2013 How would this cause the windows to steam up. I was referring too the question about wind deflectors.... ??? Quote Link to comment Share on other sites More sharing options...
Gary Watt Posted October 21, 2013 Share Posted October 21, 2013 Jackie You ordering the wind deflectors? I placed my order today. Gary 1 Quote Link to comment Share on other sites More sharing options...
JackieR Posted October 21, 2013 Share Posted October 21, 2013 Jackie You ordering the wind deflectors? I placed my order today. Gary I already have a set. Well, I do if the same ones fit this model as did the 11 Reg I had !!!! I can't see why they wouldn't mind you. I just couldn't get the windows to work with them on the last car, so took them off, back in the box and upstairs into the loft !!! Quote Link to comment Share on other sites More sharing options...
georgen Posted October 21, 2013 Share Posted October 21, 2013 Make sure you have the air recirculation off so only fresh enters the cabin or you will just keep the damp air going round in circles. This...... if you do have this on, windows will mist up very quickly. Quote Link to comment Share on other sites More sharing options...
Gary Watt Posted October 21, 2013 Share Posted October 21, 2013 Jackie Maybe someone could confirm but think they would fit. If they do I can always do it for you if you want? Gary 1 Quote Link to comment Share on other sites More sharing options...
