mick85 Posted December 18, 2013 Share Posted December 18, 2013 U will need stubby 18 or 19 an a hammer to get it off extremely tight an can't fit big spanner in that's if it rear wheeler Quote Link to comment Share on other sites More sharing options...
demikai Posted December 18, 2013 Author Share Posted December 18, 2013 No front wheel drive Quote Link to comment Share on other sites More sharing options...
demikai Posted December 18, 2013 Author Share Posted December 18, 2013 Right then egr cleaned and back in oil and filter changed and same annoying hunting (revs up and down) only on occasions tho then it's fine then does it again engine managment light still on will I need to get dealer to take it of Quote Link to comment Share on other sites More sharing options...
mick85 Posted December 18, 2013 Share Posted December 18, 2013 What's exact fault is egr still blanked off Quote Link to comment Share on other sites More sharing options...
demikai Posted December 18, 2013 Author Share Posted December 18, 2013 Can't read fault my machine won't sync with the van no I took blanking plate out Average mpg is not as good today as it has been Quote Link to comment Share on other sites More sharing options...
wase16ll Posted December 18, 2013 Share Posted December 18, 2013 egr might have been blanked as it was faulty anyway, might not just be dirty. or it maybe just code needs clearing. would also recommend changing the fuel filter if not done so already...if only to just eliminate it Quote Link to comment Share on other sites More sharing options...
wase16ll Posted December 18, 2013 Share Posted December 18, 2013 by the way, did you just clean the valve side of the egr, or did you also remove the plastic cover and cleaned the 'gearing' too...if not, do so as they often clog up with gunk too Quote Link to comment Share on other sites More sharing options...
mick85 Posted December 18, 2013 Share Posted December 18, 2013 Yeah would agree with Wase an to be honest when tryin to self diagnose without proper diagnostic u got start with basics rule things out an work way through lot cheaper then goin dealer cause fuel filter prob be first place they start did u check sensor on end of fuel rail see if it's in pieces Quote Link to comment Share on other sites More sharing options...
demikai Posted December 18, 2013 Author Share Posted December 18, 2013 Hi no changing fuel filter tomorrow there was none in at the shop next to my house so that's tomorrow's job I have not found the sensor yet I will also look for that when I change filter did you say remove the air filter box Quote Link to comment Share on other sites More sharing options...
wase16ll Posted December 18, 2013 Share Posted December 18, 2013 for the pressure sensor, yes, its under the air filter box. Quote Link to comment Share on other sites More sharing options...
demikai Posted December 19, 2013 Author Share Posted December 19, 2013 Ok thanks going to take a look at that today the engine managment light has now cleared itself no diagnostic equipment used Quote Link to comment Share on other sites More sharing options...
demikai Posted December 19, 2013 Author Share Posted December 19, 2013 I did clean all gearing on egr aswell it was surprisingly clean Quote Link to comment Share on other sites More sharing options...
wase16ll Posted December 19, 2013 Share Posted December 19, 2013 sounds like the egr is now working as it should, although light is off as its detected all is ok now, the code will still be logged, be worth clearing when you can so doesnt confuse any later issues. pressure sensor might be your problem if still experiencing the idle issue...worth looking into Quote Link to comment Share on other sites More sharing options...
demikai Posted December 19, 2013 Author Share Posted December 19, 2013 I will do thanks for all the help guys the idle seems to be improving maybe it was just coincidence but seemed to do it less as the day went on today so I think the next job is abs and traction control problem both not working locked the brakes today in rain and no abs so any ideas would be welcomed thanks again Quote Link to comment Share on other sites More sharing options...
mick85 Posted December 19, 2013 Share Posted December 19, 2013 Start wit basics fuses an wheel sensors u checked anything yet any lights on dash Quote Link to comment Share on other sites More sharing options...
wase16ll Posted December 19, 2013 Share Posted December 19, 2013 as mick suggested, its all you can do without a diagnostic as too many possibles otherwise with regards to idle, if it seems improved then run it for few days before trying anything else..gives the ecu a chance to relearn and may improve the more you drive it since the engine service/egr clean up Quote Link to comment Share on other sites More sharing options...
demikai Posted December 20, 2013 Author Share Posted December 20, 2013 Yeah I removed all sensors today cleaned and re fitted no diffrence the Idle I can live with for now but the brakes and traction need to be right especially in this weather I'm going to test the sensors to find the damaged ones and replace them hopfully it will be that simple Quote Link to comment Share on other sites More sharing options...
mick85 Posted December 20, 2013 Share Posted December 20, 2013 So wat have u checked on brakes is abs light stayin on dash Quote Link to comment Share on other sites More sharing options...
demikai Posted December 20, 2013 Author Share Posted December 20, 2013 I have only had time to remove clean and refit abs sensors not had a min to go any further with it yet hoping it's just one gone faulty Quote Link to comment Share on other sites More sharing options...
mick85 Posted December 20, 2013 Share Posted December 20, 2013 Is there a light on dash the light usually comes on if one them broke did u see any potential problems on cleaning Quote Link to comment Share on other sites More sharing options...
demikai Posted December 21, 2013 Author Share Posted December 21, 2013 Yes found it had a bit of spare time today so I had a good check over the wiring because all sensors were reading ok on multimeter and I found the damaged wire and repaired all lights now of fuel filter tomorrow and all should be well thanks to you both for all the help have a great christmas Quote Link to comment Share on other sites More sharing options...
mick85 Posted December 21, 2013 Share Posted December 21, 2013 Great when u can repair for free ha an no extra expense lucky for u so close Christmas Quote Link to comment Share on other sites More sharing options...
Big matt72 Posted February 27, 2014 Share Posted February 27, 2014 Thanks lads for posting this as I'm having same problems tho it's give me a heads up where to start Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
