xdazx Posted February 11, 2014 Share Posted February 11, 2014 Hi i have recently had a fuel pump fuel rail fuel pressure switch new glow plugs injectors and the fuel system cleaned out as i had starting problems since they was fitted the car runs a lot better when i can start it !! The problem i have now is i have to put the clutch in to start it and sometimes it takes ages to start if i can get it to start it turns over but wont fire up then sometimes it will start first time. I had the mechanic to check it with his diagnostic m/c everything electrical is working there are no faults showing. He says that its the dmf and i need to replace it and i may aswell get a clutch kit aswell. Does any1 know if that is the problem as its another huge exspense. Please help 😭 Quote Link to comment Share on other sites More sharing options...
ppeter7 Posted February 11, 2014 Share Posted February 11, 2014 it could be and or starter motor got metal filings from the dmf which is common Quote Link to comment Share on other sites More sharing options...
sambo87 Posted February 11, 2014 Share Posted February 11, 2014 Make sure egr valve isn't getting stuck and there's also a valve something to do with anti shudder there's a few posts on here that might help you out could be one of those caked up with carbon ! Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 11, 2014 Author Share Posted February 11, 2014 Some 1 else said egr valve but he would need to do test and ofcourse more money to pay out !Removed! car :( Quote Link to comment Share on other sites More sharing options...
sambo87 Posted February 11, 2014 Share Posted February 11, 2014 To prove if it's egr you can buy a blanking plate for £5.00 off eBay that's what I have done engine management light comes on sometimes due to blanking plate but car starts everytime but might be worth fitting one just to see only takes about 20 mins to fit but you could do with rubber arms :-) Quote Link to comment Share on other sites More sharing options...
sambo87 Posted February 11, 2014 Share Posted February 11, 2014 Quote Link to comment Share on other sites More sharing options...
sambo87 Posted February 11, 2014 Share Posted February 11, 2014 That was the eBay listing I bought dunno if you can see picture it doesn't let me on my I phone sometimes ! Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 11, 2014 Author Share Posted February 11, 2014 Cheers i will ask about that when i get results from the test being done 2moyo Quote Link to comment Share on other sites More sharing options...
sambo87 Posted February 11, 2014 Share Posted February 11, 2014 No problem mate Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 11, 2014 Author Share Posted February 11, 2014 What do you think about getting mondeos remaped ? Quote Link to comment Share on other sites More sharing options...
sambo87 Posted February 11, 2014 Share Posted February 11, 2014 Is it the same engine as my focus 1.8tdci 115bhp because I'm looking into it got quoted £240 with a egr delete and it was 140bhp with 300nm of torque I'm getting mine done next month gotta do some more looking but they looked a reputable company :-) Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 11, 2014 Author Share Posted February 11, 2014 No mines a 125 think it goes up2 a 150 i forgot tbh as had other things to do. My car is well foin my head in i just been to pick the mrs up went to start it without clutch would'nt go put clutch in fired up i really cannot work it out Quote Link to comment Share on other sites More sharing options...
sambo87 Posted February 11, 2014 Share Posted February 11, 2014 That does sound weird tbh good luck anyway Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 11, 2014 Author Share Posted February 11, 2014 It is well weired tbh. Hey were u from anyway ive just found the email i had from tuned n style they quoted me £175 i will paste there reply here u go on your Mondeo you are looking at 25hp and 40lb ft torque increases, so def worthwhile doing esp with the torque increase. Alongside this you would be looking at upto 20% improvement on your mpg too. Cost for me to come to you would be £175 inclusive. Hope this helps, any further questions please do ask. Regards, Nic. Quote Link to comment Share on other sites More sharing options...
sambo87 Posted February 11, 2014 Share Posted February 11, 2014 That would be great thanks I'm from Nottingham Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 11, 2014 Author Share Posted February 11, 2014 He is local to you then heres his number for you as soon as i can get car sorted and money together i will get mine done. Tuned n' Styled Mobile Remapping service for all Cars & Vans Tel: 07708 783535 Quote Link to comment Share on other sites More sharing options...
sambo87 Posted February 11, 2014 Share Posted February 11, 2014 Cheers matey appreciate it ! Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 11, 2014 Author Share Posted February 11, 2014 No probs :) Quote Link to comment Share on other sites More sharing options...
slemon123 Posted February 11, 2014 Share Posted February 11, 2014 I'd be thinking the inlet manifold is clogged up or else egr. As stated above blank off egr first to rule that out. Then look at manifold before going at dmf and clutch. Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 11, 2014 Author Share Posted February 11, 2014 Cheers m8 Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 28, 2014 Author Share Posted February 28, 2014 Hi car still the same had 5 diagnostic machines on it all showing no faults at all gad new crank sensor put on made no differant has any1 any ideas what may be the problem please :( Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
slemon123 Posted February 28, 2014 Share Posted February 28, 2014 See what you think of this. It could be this simple. You'd never know. http://www.slideshare.net/callumsmith143/ford-mondeo-18-tcdi-engine-specifications-problems Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 28, 2014 Author Share Posted February 28, 2014 Cheers for that ive had a new crank sensor on still the same not sure were the damper and washer will be tho like it says in that you just sent. The bloke that done the work keeps ssying i need a new dmf and clutch kit but cannot guarantee it will cure it but every other person i spoke to said that wont gave anything to do with starting problems ?? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
slemon123 Posted February 28, 2014 Share Posted February 28, 2014 Starting problems are either egr , inlet manifold, injectors or the vibration damper. It could be worth having a look at the immobilizer as that could be faulty. Clutch and dmf doesn't make sense to me either. Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
xdazx Posted February 28, 2014 Author Share Posted February 28, 2014 What baffles me and others is that there are no faults showing up the car is set up perfect (should be after i spent a grand on new fuel system) Quote Link to comment Share on other sites More sharing options...
