sonic113 Posted March 19, 2014 Share Posted March 19, 2014 Im looking to service the family cars soon they are: Ford Focus 2009 1.6 Zetec with 66000 on clock. Ford CMax 2010 1.6 Zetec 40000 on clock can someone suggest the best oil to use. I was going to go with Ford formula F 5w30 fully synthetic or Castrol magnatec 5w30 fully synthetic? Also should I stay with Fully Synthetic or semi synthetic. The guy at the auto parts store adised to stick with the Ford spec 5w30 Fully Synthetic. Just wondering what you guys think or any one with the same engines what you use in your cars. also if the fuel filter to be replaced on these models I read somewhere that its non serviceable but just want to check. also My service check list is as follows - oil - oil Filter - Spark Plugs - Air Filter - Pollen/Cabin Filter - Fuel Filter (If its serviceable) if i have forgot anything let me know. Thanks Quote Link to comment Share on other sites More sharing options...
Christianiani Posted March 19, 2014 Share Posted March 19, 2014 Hello Jabber. I work at a Motor Factors so hopefully can help you out a bit! You are right, the Fuel Filter on both vehicles is what they term a 'Lifetime' filter, hence we have no listing for it. As far as the oil goes, 5w30 is the correct oil grade for both vehicles and it doesn't really matter if it's Semi- or Fully Synthetic. Fully should work a bit longer before breaking down but it more depends on what you can afford!! As you have two cars to do you might opt for a cheaper oil but just make sure it's a 5w30 grade and you should be okay! Some people get caught up with spending mega-bucks on ''name brand'' oils when a decent oil of the same grade usually does just as well!! Anyway hope that helps you decide. I can't think of anything else you should change. Have fun, Chris Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 19, 2014 Share Posted March 19, 2014 It would be the ford stuff of Castrol magnatec for me, Can anyone confirm if they are the same stuff? Last time I checked the ford stuff it wasn't that expensive either for a change! 1 Quote Link to comment Share on other sites More sharing options...
ferretfloozy Posted March 19, 2014 Share Posted March 19, 2014 i usually buy this ..theyre about 2 mile from me but charge double this price if i get it over the counter ..when i queeried it they said get it off eBay then .. does'nt make sense http://www.ebay.co.uk/itm/Genuine-Ford-5W30-Fully-Synthetic-Engine-Oil-5-Litres-1502266-50-OFF-/160881010422?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item25754166f6 1 Quote Link to comment Share on other sites More sharing options...
IINexusII Posted March 19, 2014 Share Posted March 19, 2014 WSS-M2C-913-B or WSS-M2C-913-C (C being a newer and better mix, compatible with engines requiring A or B ) Castrol Magnatec Fully Synthetic 5w-30 A1 (913-A/B/C) http://www.opieoils.co.uk/p-754-castrol-magnatec-5w-30-a1-fully-synthetic-engine-oil-recommended-by-ford.aspx Mobil Super 3000 X1 Formula FE 5W-30 (913-C) www.opieoils.co.uk/p-69360-mobil-super-3000-x1-fe-5w-30-fully-synthetic-engine-oil.aspx I personally tried out Shell AF HX7 5w-30 in my last oil change which is quite decent too, and the cheapest £17 for 5l bottle http://www.eurocarparts.com/ecp/c/Ford_Focus_1.8_2005/p/car-parts/car-lubricants-and-car-fluids/lubricant-and-fluids/engineoil/?521772231&1&ca5c2f66a77874f24a6e1f721b9086ba7fd4b68b&000398 those are the three id recommend, you'd probably find cheaper prices if you go to other websites, but just showing you the bottles id recommend. i havent tried the Ford Formula FE so i cant comment on that Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 20, 2014 Share Posted March 20, 2014 Ford now use Shell oil in there services so ford oil will be rebranded Shell Quote Link to comment Share on other sites More sharing options...
sonic113 Posted March 20, 2014 Author Share Posted March 20, 2014 Thanks the reply. could i use any of the following : http://www.amazon.co.uk/Ford-Formula-Litres-Fully-Synthetic/dp/B007NZ31Q0/ref=sr_1_2?ie=UTF8&qid=1395312912&sr=8-2&keywords=ford+oil or http://www.amazon.co.uk/Castrol-Magnatec-5W-30-Engine-Oil/dp/B0042EUI16/ref=sr_1_1?ie=UTF8&qid=1395313010&sr=8-1&keywords=ford+oil also wheres the best price for oil/cabin/air filters?? where the spark plugs are concerned what is the best make/type of plug to use and also what gap shoul it be set to? Thanks again everyone for the replies. Quote Link to comment Share on other sites More sharing options...
james_60 Posted March 20, 2014 Share Posted March 20, 2014 Jabber your not listening are you lol Use the best you can afford. Its the blood of the engine :-) Jamie Quote Link to comment Share on other sites More sharing options...
sonic113 Posted March 21, 2014 Author Share Posted March 21, 2014 ok budget way i can go with ford oil 5w30 formula f or Castrol magnatec 5w30 just want to know which is best or are they as good as each other? the only good thing is the ford formula f is 5 ltrs where s the Castrol is 4ltrs just want to do a good service on the car with decent oil so I thinks its gonna be one of the above. I favour the ford formula F as is it not what ford use when the car is left in for a service but just would like your opinion. Thanks again. also whats the best spark plugs to go for? Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 21, 2014 Share Posted March 21, 2014 the ford formula f is made by Castrol mate and rebranded so they are basically the same oil plugs will be kgk iridium or Bosch super plus as standard 1 Quote Link to comment Share on other sites More sharing options...
eliaskok Posted March 21, 2014 Share Posted March 21, 2014 I use the Mobil fully synthetic one and is really good Sent from my iPad using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
mick85 Posted March 21, 2014 Share Posted March 21, 2014 Not all ford oil is Castrol unless it says on it u will no Castrol because it's green in colour but if u ask me u be better use reasonable price oil an change oil every 6 months least Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 21, 2014 Share Posted March 21, 2014 ford formula f is made by Castrol and rebranded its a bp petroleum product who make Castrol oil just like all ford stuff is, comma make Halfords brand oils it wont say Castrol on it it will be bp petroleum who make castrol and ford oil the colour is down to additives so it wont necessarily be the same colour either 1 Quote Link to comment Share on other sites More sharing options...
mick85 Posted March 21, 2014 Share Posted March 21, 2014 Yeah I agree with u art I just sayin I use get oil in grey can couple years ago off ford now they seem sell it in green can wit Castrol on front an has green dye in Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 21, 2014 Share Posted March 21, 2014 theyre always changing it was bp now its Shell they deal with but the old stock is still Castrol new stock will be Shell inside maybe Shell pay more god knows lol Quote Link to comment Share on other sites More sharing options...
mikeyd1 Posted February 21, 2017 Share Posted February 21, 2017 . Quote Link to comment Share on other sites More sharing options...
rushby-focus Posted May 2, 2019 Share Posted May 2, 2019 hi what would my ford focus 1.6 zetec 2008 what engine oil is best for it as my old focus had 5/30 part oil Quote Link to comment Share on other sites More sharing options...
F0CUE Posted May 3, 2019 Share Posted May 3, 2019 I'm going to try this next time cos the gearbox oil made my gears shift like butter. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F371348335528 Quote Link to comment Share on other sites More sharing options...
T.man Posted February 26, 2020 Share Posted February 26, 2020 Hi guys,I'm driving a 1.6 focus first generation...And currently I've been experiencing a sound of (not sure its) tappets or hydrolic lifters...I just to know it could be a matter of a worn out oil or if there could something I should immediately have a look at...Thanks have a great day.. Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 26, 2020 Share Posted February 26, 2020 6 hours ago, T.man said: Hi guys,I'm driving a 1.6 focus first generation...And currently I've been experiencing a sound of (not sure its) tappets or hydrolic lifters...I just to know it could be a matter of a worn out oil or if there could something I should immediately have a look at...Thanks have a great day.. The injectors are noisy on the 1.6 sigma it's clears up once the car is at full temperature. Quote Link to comment Share on other sites More sharing options...
T.man Posted February 26, 2020 Share Posted February 26, 2020 Yes you àre correct...Because once it is warm enough it becomes quite like all's normal...So should I be too concerned or what...Because it is continually sounding the same thing(tappets...) Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 26, 2020 Share Posted February 26, 2020 24 minutes ago, T.man said: Yes you àre correct...Because once it is warm enough it becomes quite like all's normal...So should I be too concerned or what...Because it is continually sounding the same thing(tappets...) The sigma engine has solid tappets unlike the old Zetec E found in Escorts, Orions , Mondeos and some fiestas in the early 90's. If u get a big screwdriver place the end on the injectors and the handle to you ear you should hear the tapping sound. Quote Link to comment Share on other sites More sharing options...
Bonsai20 Posted March 27, 2020 Share Posted March 27, 2020 Hi can u tel me if 5/30 semi or fully is Wat I should be using for my Ford Focus 05 plate 1.6 petrol Quote Link to comment Share on other sites More sharing options...
Bonsai20 Posted March 27, 2020 Share Posted March 27, 2020 Wat should I use 5/30 semi or fully Quote Link to comment Share on other sites More sharing options...
F0CUE Posted March 27, 2020 Share Posted March 27, 2020 Fully synthetic. Check out on https://www.opieoils.co.uk/f/2354/976/2005/engine-oil.aspx Quote Link to comment Share on other sites More sharing options...
