Mackers91 Posted April 16, 2014 Share Posted April 16, 2014 First off all hi lads Recently sold my beloved mk1 2.0 and have just bought a mk2.5 with the2.0 Duratec. I have been looking at the air feed and it seems prettypants but the space it is set in is very tight. (queue the that's whatshe said jokes )Any way does anyone here have any experience in putting in a new cold air feed or any tips ?Cheers Chris.. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 16, 2014 Share Posted April 16, 2014 All ill say is ford spent many hours lots of testing and simulations to decide thats whats best for the car Quote Link to comment Share on other sites More sharing options...
Mackers91 Posted April 16, 2014 Author Share Posted April 16, 2014 And all I'll say is that ford spent there time designing the feed around the limited space in the engine bay and the basic power output of the standard engine, hence why am asking if anyone had experience with rerouting it as this would have been my first step towards working on engine mods. I'll take you're sarcastic comment on board though, cheers for you're input. 1 Quote Link to comment Share on other sites More sharing options...
salsheikh Posted April 17, 2014 Share Posted April 17, 2014 maybe you could replace the cold air feed pipe with one that sits lower down into the main grill and attach it to the grill itself? 1 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 17, 2014 Share Posted April 17, 2014 wind youre neck in i dont do sarcastic if you had read up on it youll find that many cars are better and produce more power with the standard set up with the addition of a performance panel filter it wasnt a sarcastic comment it was a simple statement of fact... the design as limited as it may look is the better option the alternative is to buy a cold air feed and mount it behind the front bumper but the space is so limited youll have to chop parts to make it fit or have the pipe sit behind the passenger side light but again it will soak heat up from the engine bay add to that it also sucks in all the junk of the day from the front of the car more than the standard set up there are very few kits available for the 2.0 other han the induction kits which again loses power if you want to fit one attatch it to the original airbox feed pipe and look for the easiest way to route it abouut midway on the rear of the front bumper Quote Link to comment Share on other sites More sharing options...
Mackers91 Posted April 17, 2014 Author Share Posted April 17, 2014 Sorry lad, I took it as you where being one off those sarcastic keyboard cow boys.. Cheers for the advice think I've gotten it figured out I have manged to reshape and widen the standard snorkel and have I k&n replacement filter and bigger air scoop to moled to the snorkel. Quote Link to comment Share on other sites More sharing options...
theduke Posted April 20, 2014 Share Posted April 20, 2014 Im sure i read somewhere theres a bigger intake from the grill to airbox on 2.0 automatics iirc? Could've imagined it but im sure i didnt? Quote Link to comment Share on other sites More sharing options...
Lenny Posted April 20, 2014 Share Posted April 20, 2014 Hi chris, Get yourself a K&N57s kit, Consists of a bigger filter. Side cold feed induction, And a bigger top housing to keep it tidy, Well worth the spend, . And blank your EGR valve Quote Link to comment Share on other sites More sharing options...
Mackers91 Posted April 20, 2014 Author Share Posted April 20, 2014 Blank off my EGR valve? Will this not make the mill light come on? What's the benefit off doing that if you don't mind me asking? Cheers for the help. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted April 20, 2014 Share Posted April 20, 2014 Blank off my EGR valve? Will this not make the mill light come on? What's the benefit off doing that if you don't mind me asking? Cheers for the help.shouldnt do, Egr blanking stops the recirculation of exhaust waste gasses, This reduces the speed at which your oil gets dirty, Helps prevent carbon build up in the oil which can leed to turbo failure Reduces turbo lag due to increased waste gas flow, Insures your sucking in 100% clean air instead of 80% air and 20% waste gasses, For more independant feedback Click on my picture to view my profile, On my profile you will see links to 28 guides created by myself, Click on the link to guide blanking egr 1.6tdci, And have a read through other peoples experiences Juat insure you purchase a stainless steel blanking plate if you choose to blank your egr, Dont fit an alluminium blanking plate as they break through causing damage, stainless steel is the way to go. Quote Link to comment Share on other sites More sharing options...
Mackers91 Posted April 20, 2014 Author Share Posted April 20, 2014 From what I see blanking it off only really applys for diesel engines, correct me if am wrong. Mines a 2L petrol. Quote Link to comment Share on other sites More sharing options...
Lenny Posted April 20, 2014 Share Posted April 20, 2014 From what I see blanking it off only really applys for diesel engines, correct me if am wrong. Mines a 2L petrol.no your correct mate sorry my bad, I thought you went from a 2.0 mk1 diesel to a mk2.5 duratorque, But ive read it again and it is of courae a duratec, Sorry lol 1 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 21, 2014 Share Posted April 21, 2014 The 57i kit is an option but if its about cold air the enclosed kit is better the 57i to work requires constant cool air as you sit in traffic that doesnt happen so the temperature rises once you move the warm air bogs it down and it takes a good bit till cool air starts flowing through an enclosed kit keeps the inside of the filter and air cooler Anothet option is an st snorkel but the new focus like yhe mk2 has a large suppressor behind the passenger side bumper thats quite complex Quote Link to comment Share on other sites More sharing options...
JW1982 Posted April 21, 2014 Share Posted April 21, 2014 The biggest improvement would be a Focus MK2.5 RS air filter housing combined with a K&N 57S kit. The Focus RS air filter housing has 2 cold air feed pipes instead of 1 and has a much larger air snorkel. There are only a few minor modifications needed to fit a Focus RS air filter housing to a "normal" Focus MK2/MK2.5. Combined with a 60 mm throttle body of a 2.3 Duratec and smooth silicone hose instead of the standard ribbed hose it will make a noticeable difference on a 2.0 Duratec. 1 Quote Link to comment Share on other sites More sharing options...
Mackers91 Posted May 21, 2014 Author Share Posted May 21, 2014 (edited) The biggest improvement would be a Focus MK2.5 RS air filter housing combined with a K&N 57S kit. The Focus RS air filter housing has 2 cold air feed pipes instead of 1 and has a much larger air snorkel. There are only a few minor modifications needed to fit a Focus RS air filter housing to a "normal" Focus MK2/MK2.5. Combined with a 60 mm throttle body of a 2.3 Duratec and smooth silicone hose instead of the standard ribbed hose it will make a noticeable difference on a 2.0 Duratec. Only just seeing this today, I was wondering if it was possible to do just what you said with the RS filter housing and snorkel now i know it is i think i will be taking a trip to the scrapers at the weekend to get one :D i have been also looking at the silicone hosing but it seems abit expensive for what it is at around the 70£ mark :( Update Got work done on my feed this weekend, just need a silicone induction hose and the 60mm throttle body now to finish it off :) pretty happy with how it looks. http://s201.photobucket.com/user/chris-2k7-lad/media/DSC_0466.jpg.html Edited July 24, 2014 by Mackers91 Quote Link to comment Share on other sites More sharing options...
