willyjonson Posted May 4, 2014 Share Posted May 4, 2014 Hi, Can anyone explain how to change the bulb in the Glove Box,I have read a previous report but it still doesn't go far enough for me.I have dropped the Glove Box Lid but I still can't remove the bulb.There is a Allen Key screw about where the bulb/switch holder is do I have to remove that?I have unscrewed it so far but it doesn't seem to loose anything up.Anybody who can help I'd be grateful! or have you had the same trouble as me? By the way Fiesta Mk 7.5. Quote Link to comment Share on other sites More sharing options...
M4RC Posted May 4, 2014 Share Posted May 4, 2014 Does anyone have a pic of this as I plan to wire one in Quote Link to comment Share on other sites More sharing options...
LightningMat Posted May 4, 2014 Share Posted May 4, 2014 No need to undo any screws or allen bolts on mine - it is just a push fit - carefully squeeze the two clips at the front (one of the clips is around the actual switch post itself, the other a couple of cm's to the right). It is attached fairly tight (as you would expect), but with a bit of careful persistence, does come off. Once off, I had to dismantle it to get the old bulb out and new bulb in, but again, is just clipped together with 4 clips - 2 each side - gently push each one in with a small screwdriver... Oh, and watch out, because it is spring loaded!! See pic... 1 Quote Link to comment Share on other sites More sharing options...
willyjonson Posted May 6, 2014 Author Share Posted May 6, 2014 Thanks Lightning for the Info and Photo.I changed bulb yesterday in 5 mins.I don't know what I was messing about at before, I think it's not quite knowing whats tied up with what and hence breaking something because of it. Anyway thanks for everything and the time to bother. Quote Link to comment Share on other sites More sharing options...
LightningMat Posted May 6, 2014 Share Posted May 6, 2014 No problem, happy to help! I know what you mean though, is very difficult to see some things, so when someone else has already done it, make the whole process a lot easier. Quote Link to comment Share on other sites More sharing options...
