Enko Posted September 4, 2014 Share Posted September 4, 2014 Someone has offered me their alloys from a saab they are scrapping so was just wondering if anyone can tell me if they are likely to fit without using a hub ring? I believe the pcd is the same but the center bore is 65.1 whereas my mondeo is 63.4 Basically is it possible to do a straight swap or is that unsafe or illegal? ....may just try them tomorrow anyway unless someone tells me its a waste of time. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 5, 2014 Share Posted September 5, 2014 Definately worth trying them! Have a look at my signature "what wheels will fit my ride" and check the list, it might help you. Quote Link to comment Share on other sites More sharing options...
Enko Posted September 5, 2014 Author Share Posted September 5, 2014 Thanks. I don't think it's going to be as straight forward as I hoped so will probably save my pennies up for some i know will fit but may still try them out. Quote Link to comment Share on other sites More sharing options...
stevegtuk Posted September 5, 2014 Share Posted September 5, 2014 these are the vehicles whose wheels will definitely fit yours http://www.wheel-fitment.com/car/Ford/Mondeo%20%282000%20-%202007%29/ Quote Link to comment Share on other sites More sharing options...
Enko Posted September 5, 2014 Author Share Posted September 5, 2014 Thanks I had a look but really I just wasn't sure if using wheels with a slightly larger center bore would matter without a hub ring Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted October 13, 2014 Share Posted October 13, 2014 Hey guys does anyone know if its ok to use a 15 inch spare on a car with 17 inch alloys?? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 13, 2014 Share Posted October 13, 2014 Should be fine Damon for spare use only of course Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted October 13, 2014 Share Posted October 13, 2014 Ok cool i ask because ive sold my old alloys which includes my spare need to buy a new spare is best to buy space saver or steel Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 13, 2014 Share Posted October 13, 2014 Go steel, space saver is speed limited, a spare dull size steel will go full speed but a 15 on 17s would need to be speed limited. Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted October 13, 2014 Share Posted October 13, 2014 Id buy. 17 inch spare but it wont fit in the wheel well in my boot so guna have to be 15 inch no matter wether its space saver or steel so does it matter which one i get cant flreally go over 70 anyway due to having a black box Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 13, 2014 Share Posted October 13, 2014 it doesn't matter no. I would prefer the steel, less pressure in the tyre and stronger to support. I have a 17 inch alloy in my boot I'm going to make a false bottom and raise the boot floor up. Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted October 13, 2014 Share Posted October 13, 2014 Got a mk1 focus id lose alot of space if i did that Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 13, 2014 Share Posted October 13, 2014 Ah fair enough I can understand that. In which case go slower but a steel 15 is a good choice Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted October 13, 2014 Share Posted October 13, 2014 Cool bit gutted tho only got 45 for my alloys tho for 5 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 13, 2014 Share Posted October 13, 2014 Crikey you were ripped off there weren't you? Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted October 13, 2014 Share Posted October 13, 2014 Yep but i just wanted rid they needed a refurb on 2 of them and one needed abit of paintin up covering curb damage Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 13, 2014 Share Posted October 13, 2014 Still more money in your pocket is better than in someone else's. Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted October 13, 2014 Share Posted October 13, 2014 True but gotta buy a steel now so no better off really Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 13, 2014 Share Posted October 13, 2014 That's true also Quote Link to comment Share on other sites More sharing options...
theredfox Posted October 29, 2014 Share Posted October 29, 2014 it doesn't matter no. I would prefer the steel, less pressure in the tyre and stronger to support. I have a 17 inch alloy in my boot I'm going to make a false bottom and raise the boot floor up. did you ever get round to this 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted October 29, 2014 Share Posted October 29, 2014 did you ever get round to thisI reckon this could be custom built using some light plastic sheets sold as painters sheets in DIY store, Line the boot with it, Get yourself a mask and five cans of expanding foam, Apply layers giving it time to set, Can trim it with Stanley blade when fully hardened, Strong and light, Quote Link to comment Share on other sites More sharing options...
theredfox Posted October 29, 2014 Share Posted October 29, 2014 could me messy lenny that foam sticks every where does not matter how careful you are 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted October 29, 2014 Share Posted October 29, 2014 could me messy lenny that foam sticks every where does not matter how careful you are true enough mate, Only other option i can think of is two sections cut out of mdf, With stilts type side pieces underneath to raise the floor up, Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted October 30, 2014 Share Posted October 30, 2014 If you get some evo stick resin some 2x4 to make batons glue them to the floor of the boot then make a plywood base and screw to the batons should be solid enough done something similar in the van to store step ladders Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 25, 2014 Share Posted November 25, 2014 did you ever get round to this Sorry mate, took a while! Yes, I am still in the process of finishing it, whilst its not as pretty as the Ford factory set. its effective and efficient. I must admit, I didnt really make the effort to make it look pretty, also my DIY shack is little more than a lean to where I hold the wood still with my left hand as I saw the wood with the right lol. I will take some snaps as and when I get around to finalising it. Quote Link to comment Share on other sites More sharing options...
