dave maden Posted October 20, 2014 Share Posted October 20, 2014 i have a 2008 fiesta 1242cc and the key fob is taking a few presses o open the doors , so i think it needs a new battery , when i change the battery , will the key need re-programming for the central locking to work gain and if so how would i re-program it . thanks Quote Link to comment Share on other sites More sharing options...
KenP Posted October 20, 2014 Share Posted October 20, 2014 No, just change the battery, it will work fine. Quote Link to comment Share on other sites More sharing options...
williamweb Posted October 20, 2014 Share Posted October 20, 2014 I think Ford recommends a battery change every 3 years. Quote Link to comment Share on other sites More sharing options...
CV 66 Posted October 20, 2014 Share Posted October 20, 2014 When I came to change the battery on the key of my first Fiesta (back in 1997), I remember the guy at Ford telling me it had to be changed within a minute of taking the old battery out, otherwise it would need to be re-programmed. I don't honestly know if this still applies these days as I've since had the mechanics change it whilst the car was having its service. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 21, 2014 Share Posted October 21, 2014 As long as you swap the batteries promptly you will be ok. Make sure all contacts are correctly seated before closing the fob up. Quote Link to comment Share on other sites More sharing options...
dave maden Posted October 21, 2014 Author Share Posted October 21, 2014 thanks for all your help , will get a battery and try it , where would be best place to get a battery ? thanks . also if i cant change it quick enough , how do you re-program it ? Quote Link to comment Share on other sites More sharing options...
Diohix Posted October 21, 2014 Share Posted October 21, 2014 Do you know what battery is needed? Mine needs changing, have to stand right next to the car for it to unlock which is getting a bit annoying! :P Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 21, 2014 Share Posted October 21, 2014 Ford routinely use a CR2032 battery. If you need to program the rcl- INSERT KEY INTO IGNITION 1- TURN IGNITION SWITCH FROM POSITON 1 TO POSITION II, 4 TIMES WITHIN 6 SECONDS, FINISHING AT POSITION 1, THE SYSTEM WILL CHIME / BLEEP 2- WITHIN 10 SECONDS PRESS AND HOLD ANY BUTTON ON THE REMOTE KEY FOB, THE SYSTEM WILL CHIME / BLEEP WITHIN 10 SECONDS PRESS BUTTON ON ANY OTHER REMOTE TO BE PROGRAMMED. 3- TURN IGNITION TO POSITION II FOR 10 SECONDS 4- TURN IGNITON OFF AND REMOVE KEYS 5- TEST REMOTE KEY FOB 1 Quote Link to comment Share on other sites More sharing options...
dave maden Posted October 21, 2014 Author Share Posted October 21, 2014 thanks very much . Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 21, 2014 Share Posted October 21, 2014 You're welcome. Quote Link to comment Share on other sites More sharing options...
Philf1 Posted October 21, 2014 Share Posted October 21, 2014 Get your battery from a jeweller/watch repair place. If you have a local market they will be cheaper still. Otherwise supermarkets tend to sell them but they are often duracell so cost a tad more. Quote Link to comment Share on other sites More sharing options...
dave maden Posted October 21, 2014 Author Share Posted October 21, 2014 thanks , ive just ordered a pack of 10 duracell ones off e-bay £5.75 . they are the same size for kitchen/bathroom scales , so will get used . 1 Quote Link to comment Share on other sites More sharing options...
dave maden Posted October 27, 2014 Author Share Posted October 27, 2014 ok just an update , fit the battery , no problem and all seems fine . thanks for your help 1 Quote Link to comment Share on other sites More sharing options...
