Russhux Posted May 6, 2015 Share Posted May 6, 2015 Hi, my 2011 s max keeps going into limp mode or cutting out completely. After their diagnostics machine was connected there was two faults, low fuel pressure and high fuel pressure! It's been recommended up I change the fuel filter as a starting point as small cost of £100. Has anyone got any experiences of changing this filter? Or know where I can find some more information about changing the filter and priming it. Any help would be very great. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Russhux Posted May 7, 2015 Author Share Posted May 7, 2015 Bump Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 8, 2015 Share Posted May 8, 2015 the filter changes are fairly simple, but they require patience. You need to get the new filter and brim it with fuel as your installing it, then open the bleed nipple and squirt some more diesel in there to in essence cause it to overflow. As you try to start it the first few times, it will struggle, and may well cut out, but if you put enough diesel in, it should run fine from about two or three restarts. Quote Link to comment Share on other sites More sharing options...
Russhux Posted May 8, 2015 Author Share Posted May 8, 2015 Thanks, I am planning on attending this on Monday. I couldn't believe the cost of the fuel filter £75 Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 8, 2015 Share Posted May 8, 2015 That's bad, you could get an aftermarket for about 20! Quote Link to comment Share on other sites More sharing options...
Russhux Posted May 14, 2015 Author Share Posted May 14, 2015 Fuel filter change competed today. I filled the filter with diesel from one of the inlet hose until it was full. Then reconnected all the hose's and started the car. it was fine, didn't misfire or cut out. It took a minute or so to remove some hair bubbles that can be seen from the clear pipe. Hopefully it's fixed the fuel rail low-pressure issue I had. Saved my self about £100 Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 14, 2015 Share Posted May 14, 2015 Glad you got it done fella, not a difficult job really but one requiring patience. Quote Link to comment Share on other sites More sharing options...
theredfox Posted May 14, 2015 Share Posted May 14, 2015 did you buy the ford filter at that price Quote Link to comment Share on other sites More sharing options...
Russhux Posted May 29, 2015 Author Share Posted May 29, 2015 I got the genuine Ford filter online for £70. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
