Phen0mable Posted July 19, 2015 Share Posted July 19, 2015 Can I simply replace speedometer without any computer confusion, mileage loss or other problems ?? My indicator "click" is gone and I found out that this click comes from speedometer itself. There is small speaker installed inside. I'm not sure if I can simply disconnect speedometer and take it apart without any problems with computer etc. I took speedometer out I then realised that cable socket is secured and hard to pull out. I think it maybe because I can't just simply disconnect it. I've spoken with ford electrician at my local ford service and he said that if indicators work then relay is OK and for "click" sound when indicating I need to investigate. I'm not quiet sure what will happen when I simply disconnect speedo.. Has anyone of you done it before ?? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 19, 2015 Share Posted July 19, 2015 You can remove the cluster with no problems except that the car won't start without it. Send the cluster to these people and they'll fix it for you - http://www.clusterrepairsuk.co.uk/repair/make/ford If you were to swap the cluster with a replacement one you will need someone with access to an IDS module to pair the cluster to the immobiliser system on the car or else it won't start. 1 Quote Link to comment Share on other sites More sharing options...
Phen0mable Posted July 19, 2015 Author Share Posted July 19, 2015 Thanks. I'll take the cluster out and make sure that the fault I have is really down to speaker .. I don't want to spend small fortune for nothing ;-) 1 Quote Link to comment Share on other sites More sharing options...
Phen0mable Posted July 19, 2015 Author Share Posted July 19, 2015 Just noticed there that the warning sound for the head lamps being left on when you open the drivers door isn't working either Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 19, 2015 Share Posted July 19, 2015 It's all from the same piezo electric sounder on the cluster board. 1 Quote Link to comment Share on other sites More sharing options...
Phen0mable Posted July 19, 2015 Author Share Posted July 19, 2015 That's a good news because I can get a this speaker from other cluster :-) Quote Link to comment Share on other sites More sharing options...
Phen0mable Posted July 20, 2015 Author Share Posted July 20, 2015 I got my cluster apart and it start to click and beep :D Unfortunately after few seconds it died again .. I believe that piezoelectric sounder is OK .. I need to contact service to test and fix my IC Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 20, 2015 Share Posted July 20, 2015 Has to be a loose connection somewhere. Quote Link to comment Share on other sites More sharing options...
Phen0mable Posted July 20, 2015 Author Share Posted July 20, 2015 I did fiddle around with cables I found behind IC .. Do you have in mind some particularly place ? Quote Link to comment Share on other sites More sharing options...
Phen0mable Posted July 21, 2015 Author Share Posted July 21, 2015 I managed to get hold of another IC and everything works .. I didn't try to start the engine once I spot that mileage is not mine but all controls, beeps, clicks etc works just fine .. Looks like my IC is faulty and I need to send it to London for repair .. Thank you Stoney871 for interest and link to that company .. 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 21, 2015 Share Posted July 21, 2015 Keep us updated on progress. Glad to help :) Quote Link to comment Share on other sites More sharing options...
Phen0mable Posted July 21, 2015 Author Share Posted July 21, 2015 I will. Once I get it back from repair I'll tell you how much they charged me and if they managed to fix it 1 Quote Link to comment Share on other sites More sharing options...
