chrisjbooth Posted August 30, 2015 Share Posted August 30, 2015 Hello As the title says I get vibrations through the steering wheel at 60mph +. No issues at low speeds or braking. Any ideas? Cheers! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 30, 2015 Share Posted August 30, 2015 Matching tyres with correct pressures all round? Quote Link to comment Share on other sites More sharing options...
artscot79 Posted August 31, 2015 Share Posted August 31, 2015 Wheel imbalance especially with alloys pot holes can cause small buckles making it vibrate like mad at high speed in most cases getting them balanced will help if not you'll have to have the rears checked if they ate better swap them to the front Quote Link to comment Share on other sites More sharing options...
chrisjbooth Posted August 31, 2015 Author Share Posted August 31, 2015 Correct pressures, not matching tyres tho. The car has steel wheels on it, not alloys. I'll have to look at getting the wheels balanced up and see if that makes a difference. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 31, 2015 Share Posted August 31, 2015 Non matching tyres can cause problems beyond what you would imagine. Non matching tyres on a common axle will cause handling irregularities, however you can have different ones front & back in matching pairs. I would get the tyres checked for bulges/splits/wear pattern to eliminate variables that can cause problems. 1 Quote Link to comment Share on other sites More sharing options...
V6 Lover Posted August 31, 2015 Share Posted August 31, 2015 To me..mismatched tyres tells whoever put them there....not nescceseraly the present owner, is probably not too clued up about tyres or their impact where handling dynamics are concerned.... Your motor only has handprint size contact with the road at all times..a little patch at each corner isn't much...different tyres on the same axle is sort of inviting comedy car handling..full matching set and you really can't go to far wrong.. Quote Link to comment Share on other sites More sharing options...
