hifromrich Posted December 27, 2015 Share Posted December 27, 2015 Hi all, In the last few days a 'Engine System Failure' message has appeared on the dash together with the car going into limp mode. (2006 Focus 1.6TDCI). I've got several OBD code readers but neither of them will power up using the diagnostic port, both readers have worked on the car before. I've put a multimeter to the power pins but not getting anything. Has anyone had any experience of this before? Quote Link to comment Share on other sites More sharing options...
ajzetecs Posted December 27, 2015 Share Posted December 27, 2015 try disconnecting battery for 5 mins might reset something Quote Link to comment Share on other sites More sharing options...
alexp999 Posted December 27, 2015 Share Posted December 27, 2015 Have you checked the relevant fuse? 1 Quote Link to comment Share on other sites More sharing options...
hifromrich Posted December 27, 2015 Author Share Posted December 27, 2015 Have you checked the relevant fuse? I've checked a few fuses, although it's not clear from the diagram which fuse it uses. Some references online say it uses Fuse 39 (12v Outlet), that was blown but now works fine and some say Fuse 46 (Instrument cluster/on board diagnostics) but that checked out OK. I suppose I might have to check them all, just in case. Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted December 27, 2015 Share Posted December 27, 2015 Hi, a little OT but, where is the OBD port on the mondeo 2015 and what app can you use on the android phone or iPad? Thanks Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
hifromrich Posted December 27, 2015 Author Share Posted December 27, 2015 I've checked a few fuses, although it's not clear from the diagram which fuse it uses. Some references online say it uses Fuse 39 (12v Outlet), that was blown but now works fine and some say Fuse 46 (Instrument cluster/on board diagnostics) but that checked out OK. I suppose I might have to check them all, just in case. Ok, I've checked all the fuses and all are ok. Could there be a fuse for it somewhere else? Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted December 27, 2015 Share Posted December 27, 2015 Could it be a fuse under the bonnet? I'm not familiar at all but it could be. Quote Link to comment Share on other sites More sharing options...
iantt Posted December 27, 2015 Share Posted December 27, 2015 Fuse 46 it should be if your car made after12/2005, before is fuse 44 2 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted December 27, 2015 Share Posted December 27, 2015 I read somewhere fuse 19 under the bonnet. Quote Link to comment Share on other sites More sharing options...
iantt Posted December 27, 2015 Share Posted December 27, 2015 Have you got 12v at those fuses? And no voltage at dlc pin 16? And you have earth on pin4? Quote Link to comment Share on other sites More sharing options...
iantt Posted December 27, 2015 Share Posted December 27, 2015 If you do have power to fuse but not at dlc then theres a break in the circiut somewhere, you need to trace the pin on connector of cjb and do resistance check between connector pin and dlc pin 16. Quote Link to comment Share on other sites More sharing options...
hifromrich Posted December 27, 2015 Author Share Posted December 27, 2015 If you do have power to fuse but not at dlc then theres a break in the circiut somewhere, you need to trace the pin on connector of cjb and do resistance check between connector pin and dlc pin 16. I'll re-check those fuses and see if i've got power there. If it's shared with the instrument cluster then it should be ok as it works fine. I think i'll do another check on the pins tomorrow. Thanks all for the input. Quote Link to comment Share on other sites More sharing options...
hifromrich Posted December 28, 2015 Author Share Posted December 28, 2015 Ok, problem solved. It was as simple as replacing a missing fuse! Oddly it was a fuse in a slot listed as 'Unused' in both of the different fuse box diagrams I found! Quote Link to comment Share on other sites More sharing options...
iantt Posted December 28, 2015 Share Posted December 28, 2015 Thats good, now you can let us know what your engine light on was. 1 Quote Link to comment Share on other sites More sharing options...
hifromrich Posted December 28, 2015 Author Share Posted December 28, 2015 Thats good, now you can let us know what your engine light on was. Yep, the P2002 DPF efficiency code was present and the other one was P0380 Glow Plug circuit. Both have now cleared off as current codes, but it's still in limp mode with the little red LED and Engine System Fault on the dash. Apparently it's not uncommon for a faulty glow plug to bring up this warning as they are used for other tasks other than just starting the car. I think changing these is the next step forward although i'm conscious of the fact that (as far as I know) the car is still on its original DPF with 112k! Quote Link to comment Share on other sites More sharing options...
iantt Posted December 28, 2015 Share Posted December 28, 2015 Thats good, normaly dont get past 80k, you need a proper dtc check that reads more than the generic codes of than a normal reader. 1 Quote Link to comment Share on other sites More sharing options...
hifromrich Posted December 28, 2015 Author Share Posted December 28, 2015 Thats good, normaly dont get past 80k, you need a proper dtc check that reads more than the generic codes of than a normal reader. Well, I bought the car with 79k on the clock and there's nothing in the service history to say that it had been replaced, but I suppose it could have! Yes i'm going to get it booked in to get a garage to have a look, i'd change the plugs myself but they don't look easy to get too. Also going to have a look at the hoses for the DPF to see if it's causing the P2002 code. Quote Link to comment Share on other sites More sharing options...
simcor Posted December 29, 2015 Share Posted December 29, 2015 Mine needed glow plugs replacing not long after I got it, mine had 63K or 68K on it when I bought it. And yes glow plugs can cause the red engine light and limp home mode. Quote Link to comment Share on other sites More sharing options...
