Jason87 Posted May 24, 2016 Share Posted May 24, 2016 Notice my tdci has a sort of whine/buzz coming from the area near the coolant resevoir, the noise changes as I turn the wheel, is this Anythjng bad? Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted May 24, 2016 Share Posted May 24, 2016 The Electro-Hydraulic Steering pump is just below the drivers side headlamp, not far from the reservoir. Some sort of sound from this will be normal as the steering wheel is turned, or if there is any force applied to it (assuming the engine is running). Perhaps check the fluid level in the reservoir (I have a mk 2 Focus, & the cap is easily visible if the headlamp is removed). If the level is ok, if the steering feels ok, if the warning light or message for the steering stays off, and the noise does not appreciably change, then I do not think there is anything to worry about. These steering units are usually very reliable. Peter. 1 Quote Link to comment Share on other sites More sharing options...
Jason87 Posted May 25, 2016 Author Share Posted May 25, 2016 It was a constant sound and it changes when I move the wheel which must mean it's the steering pump, but I don't know if the sound is normal being constant or means a fault? Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted May 25, 2016 Share Posted May 25, 2016 i think the whine is coming from the air intake system, where the air comes up from the intercooler and joins the hand plastic part that I think is the bypass for the turbo? there is a connector there which I think might be the anti shudder? sounds like its coming from there Quote Link to comment Share on other sites More sharing options...
