v530anh Posted September 23, 2016 Share Posted September 23, 2016 The old coil may be the original as it is fomoco, I got a new Bosch coil. I believe it is every 100 000 miles, though I am leaving it late at 118 500 miles for the service change. But torx screwdrivers have no grip vertically, but horizontally that is a different story. I only managed to remove one screw and rounded one at the back. I just used tie ins to put the new coil on on top of the oil coil, it seems well fitted. So only 2 questions: Which is the best tool to remove torx screws at a difficult position and how to remove the rounded torx screw. Also the new coil is idle at 1000 rpm, not 900 rpm as with the old coil. But when car heats up it idles at 900 rpm. Is this normal, though the new coil seems to make the car accelerate more at different gears. Quote Link to comment Share on other sites More sharing options...
TangoDaz Posted September 24, 2016 Share Posted September 24, 2016 When changing the coil pack its advised that you change your plugs Quote Link to comment Share on other sites More sharing options...
v530anh Posted September 25, 2016 Author Share Posted September 25, 2016 I changed the plugs and leads this summer. Quote Link to comment Share on other sites More sharing options...
Chris_Focus93 Posted September 25, 2016 Share Posted September 25, 2016 On 9/23/2016 at 8:31 AM, v530anh said: Also the new coil is idle at 1000 rpm, not 900 rpm as with the old coil. But when car heats up it idles at 900 rpm. Is this normal, though the new coil seems to make the car accelerate more at different gears. Wouldn't worry about this too much, sounds as if this is fixing a worn Coil. Best way is to have a adjustable ratchet socket with a torx adaptor, if you've rounded it off, try a bigger one instead. Worstcase just get a big screwdriver (flat head) and hammer it into the bolt to make your own "leverage". If you have replacements you could drill it out but there's likely easier ways! 1 Quote Link to comment Share on other sites More sharing options...
v530anh Posted September 26, 2016 Author Share Posted September 26, 2016 I rounded another rear screw with a 18V drill, even on full power the drill was not turning, don't like torx. I would have to drill it out.... Quote Link to comment Share on other sites More sharing options...
