Yaniv Posted December 14, 2016 Share Posted December 14, 2016 Hi, I want to change the original Speakers in my Focus 2008. Is this set of component Speakers will fit in size? especially the tweeters. http://www.rainbow-audio.de/en/speaker/sound-line-pro/ SL-C6.2 PRO Part No.: 231313 + COMPARE SHARE 2-way 6.5 inch (16,5 cm) Compo Set 25 mm Silk dome Tweeter Max. 180 Watts Minimum Amplifier Power: 75 Watts Frequency Responce: 45 Hz – 30 kHz BTW, when can I installed the cross units so they can be accessible quite easily? Thank for your help. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 14, 2016 Share Posted December 14, 2016 1 hour ago, Yaniv said: Hi Yaniv, I want to change the original speakers in my Focus 2008. Is this set of component speakers will fit in size? especially the tweeters. http://www.rainbow-audio.de/en/speaker/sound-line-pro/ SL-C6.2 PRO Part No.: 231313 + COMPARE SHARE 2-way 6.5 inch (16,5 cm) Compo Set 25 mm Silk dome Tweeter Max. 180 Watts Minimum Amplifier Power: 75 Watts Frequency Responce: 45 Hz – 30 kHz BTW, when can I installed the cross units so they can be accessible quite easily? Thank for your help. Hi, 6.5" components are the correct size for both front & rear fitment in your model of focus, you will also need to purchase some model specific "aftermarket speaker adaptors" there sold in pairs; different pair for front and rear doors both take a 6.5" speaker size and the M6x20 bolts with washers and lock nuts were purchased seperatly from local DIY store. Front: Rear: The size of the tweeters won't be any issue as they fit inside the existing Ford grill on the front doors with the use of a dremil style rotary tool to bore out a little plastic inside the grill; I've fitted 25.4mm JL Audio tweeters in mine without a problem. the rear door cards have a marking embossed on the inside; showing the area to drill from inside when fitting tweeters because models fitted with the ✌premium✌factory audio models had rear tweeters fitted as standard my build thread displays images of the process if you take the time to find the correct page for speaker upgrade you will see the images, I've linked all parts suppliers in the build and used some 3M Velcro pads to mount the crossovers on the doors, easiest location unless you run a second audio feed from the main chassis in to the doors which can be alot of trouble to get through. However if you do decide to put an extra audio feed in to the doors and mount the crossovers under the seats; my guide here will show how to get that extra cable in there Guide to fitting Ford puddle lights Focus 05-12 Click Here 👇Built Thread👇 I've also created a series of guides which may also assist you in the audio visual 👍 Guide to Fitting Aftermarket headunit focus Mk2 & Mk2.5 Click Here Guide To fitting 10" HD Flip Down Monitor Focus Mk2 & Mk2.5 Click Here Custom 10" Sub enclosure & Amp panel Focus Mk2 & Mk2.5Click Here Guide Installing Reverse Camera Focus Mk2.5 2008 - 2011Click Here Guide Fitting Dual Camera DVR System Focus Mk2 & Mk2.5Click Here my full list of Guides can be found here: https://www.google.ie/url?sa=t&source=web&rct=j&url=http://www.fordownersclub.com/forums/topic/68214-full-list-lennys-guides/&ved=0ahUKEwjn7qbyhvTQAhXkCcAKHXCrAVMQFggaMAA&usg=AFQjCNF_jUzFEqw5X3E-vCcv_8WqIoSgew Quote Link to comment Share on other sites More sharing options...
Jon84 Posted December 15, 2016 Share Posted December 15, 2016 For decent comps like them, you'll be better off with an MDF Baffle. 1 Quote Link to comment Share on other sites More sharing options...
tazzman600 Posted December 15, 2016 Share Posted December 15, 2016 Very true regarding MDF panels but an alternative is to wrap sound deadening material around the plastic speaker adapter so the sound deadening melds onto the speaker chassis and to the door panel. Much easier to do this than measure and cut and shape MDF and it's cheaper too and just as good if not better than MDF adapter. 1 Quote Link to comment Share on other sites More sharing options...
goldtail77 Posted December 15, 2016 Share Posted December 15, 2016 So disappointed, I came in here hoping to see a Focus with an SL 6litre V8 installed 1 Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted December 15, 2016 Share Posted December 15, 2016 5 minutes ago, goldtail77 said: So disappointed, I came in here hoping to see a Focus with an SL 6litre V8 installed Could you imagine the noise and speed of that thing flying down the road! Quote Link to comment Share on other sites More sharing options...
goldtail77 Posted December 15, 2016 Share Posted December 15, 2016 2 minutes ago, DJ_Andy_M said: Could you imagine the noise and speed of that thing flying down the road! Noise, with that Rocket in Space no one would hear you scream. Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 15, 2016 Share Posted December 15, 2016 13 hours ago, Jon84 said: For decent comps like them, you'll be better off with an MDF Baffle. MDF spacers would be an alternitive option to the plastic version, It's worth taking note; The front doors would need some atleast 25mm thick mdf to space the speaker out far enough from the inner panel ensuring theres sufficent depth within the door cavity for the cone of the speaker to recess in without touching the outer door panel or obstructing the window glass when it's in the fully open position. The rear door spacers wouldn't need to be quite as thick as the front door ones because the door cavity in the rear quarter is deeper at that particular mounting location. I've used some 6.5" DEi Boom Mat speaker cup baffles in all four doors to prevent resonance through the panels and keep the bass in the car, they work very well I get deep bass without any resonance through panels👌 There available in various diameters to match all speaker sizes and have micro particles of volcanic ash within there mixture of construction which is super light weight and reflects the noise quite well, these baffles also protect the Speakers from any moisture within the door cavitys; should the window seals fail at some point the Speakers won't get hurt. 2 Quote Link to comment Share on other sites More sharing options...
Jon84 Posted December 16, 2016 Share Posted December 16, 2016 13 hours ago, Lenny said: MDF spacers would be an alternitive option to the plastic version, It's worth taking note; The front doors would need some atleast 25mm thick mdf to space the speaker out far enough from the inner panel ensuring theres sufficent depth within the door cavity for the cone of the speaker to recess in without touching the outer door panel or obstructing the window glass when it's in the fully open position. The rear door spacers wouldn't need to be quite as thick as the front door ones because the door cavity in the rear quarter is deeper at that particular mounting location. I've used some 6.5" DEi Boom Mat speaker cup baffles in all four doors to prevent resonance through the panels and keep the bass in the car, they work very well I get deep bass without any resonance through panels👌 There available in various diameters to match all speaker sizes and have micro particles of volcanic ash within there mixture of construction which is super light weight and reflects the noise quite well, these baffles also protect the speakers from any moisture within the door cavitys; should the window seals fail at some point the speakers won't get hurt. The Boom mats look like a great idea, I've noticed a little vibration on the front doors especially. I've only got cheap Pioneers run off the HU, so these could help alot. Do you have a preferred supplier? 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 16, 2016 Share Posted December 16, 2016 38 minutes ago, Jon84 said: The Boom Mats look like a great idea, I've noticed a little vibration on the front doors especially. I've only got cheap Pioneers run off the HU, so these could help alot. Do you have a preferred supplier? They prevent vibration transfer from Speakers to doors aswell as other benefits, ive no preferred supplier on these mate, I just went on to eBay UK and purchased from the cheapest supplier at the time. 1 Quote Link to comment Share on other sites More sharing options...
Jon84 Posted December 16, 2016 Share Posted December 16, 2016 1 hour ago, Lenny said: They prevent vibration transfer from speakers to doors aswell as other benefits, ive no preferred supplier on these mate, I just went on to eBay UK and purchased from the cheapest supplier at the time. Sounds like something to go for in the new year! Thanks Lenny :) 1 Quote Link to comment Share on other sites More sharing options...
